Question about Frigidaire GLTF2940ES Front Load Washer
Door will not close
The door will not close either with laundry or empty. How do i get it to close?
I'm having the same problem. Just keeps buzzing. Seems like a door switch issue
Posted on Jun 09, 2010
Washer not running, how can I unlock the door to get my laundry?
There is some good advice here. I had a similar problem. I pulled the plug, counted to ten and plugged it back in, and it unlocked.
Is there water in the machine? If so, remove the drain hose and lower it into a bucket and get the water level down to as empty as you can.
https://answers.yahoo.com/question/index?qid=20080914155354AAjtqMB
Aug 06, 2015 | Whirlpool WFW94HEXW-WGD94HEXW Laundry
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
I went to put laundry in the empty washer to find it was filled with water. Why would it fill up with water while just sitting unused (and the door partiallly open - I have always had to leave the door...
It sounds like you have a failing inlet valve. The inlet valves have springs that push them closed when the machine doesn't require water. When you start a load of clothes, the machine controller sends electricity to the inlet valves. The electricity (via magnetism) overcomes the springs and opens the valves. Your valves aren't closing all the way due to them either failing or having a foreign object holding them open.
In either case, you need to replace the inlet valve assembly ASAP. Failure to replace these valves could result in your machine flooding- not a good situation.
Good luck.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I put a load of clothes on to wash and left the laundry room and everything was fine. When I returned the whole laundry room floor was flooded! I can not see where any of the incoming water lines or the...
Did you have a small part of clothing sticking out the door? Water can leak past the door seal on this case. Other than that, run the machine empty u ntill you find the leak location.
Jan 19, 2018 | Kenmore 24832 Top Load Washer
Sour smell inside washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jul 11, 2009 | GE WHRE5260E Top Load Washer
Odor from the inside of our front load laundry washer
leave the door ajar between uses if possible , there is a product on the market now to assist the odors of front loaders. www.affersh.com . you MUST also use an HE detergent ( specifically designed for front loading washers)
Nov 13, 2008 | Kenmore Washing Machines
Laundry washer broke
if the top door lid sensor is bad it will refuse to wash or spin.
do you hear it click when you open and close it.
try pushing it in manually to see if it makes a diff.
Jan 31, 2008 | Washing Machines
Door is locked! Won't open! Laundry is stuck inside!
If the water has not completely emptied, this wont allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump blockage
Oct 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
47 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
