Question about Sony NV-U73T GPS Receiver
How to change the battery
How to change the internal battery - sony says it must be replaced by factory-trained personnel
    Brigadier General:
  • 4,090 Answers
And if you try to do it yourself you will learn why they suggest that! Screws in strange places and many little items that are difficult to get back in place. Also the battery is unique and not available on the common market.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 06, 2010
  • sanjiv_a2000 May 30, 2011
    any idea what Sony would charge to replace the battery in NV-U73T, and how to contact them?
How to replace Moto G battery
CONTACT US if you believe you need your battery changed. This model has a non removable battery. We have trained techs to provide such repairs.
Mark
Motorola Support
May 13, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Bios battery removal
the bios/cmos battery (usually a button type) is fairly easy to remove and can be done anytime the computer is unplugged from the power (switched off at the wall) however it is recommended that this procedure only be done by trained personnel
NOTE: removing this battery will reset the system date and time
Feb 12, 2014 | Intel Computers & Internet
How to change spark plugs on 2008 ford taures 3.5 sel
They are under the coilpacks, it isn't easy and should be lest to trained personnel, you can damage the packs if you pull on them too much.
Jan 29, 2013 | Motorsports
Engine will turn over/crank but will not run
All internal combustion engines have the same requirements. They must have the correct air fuel mixture and source of ignition in order to run. Although I am unfamiliar with the system you have, the fact thst it will start without the air filter but won't with the air filter indicates that you either have a dirty air filter (you said yours was clean) or you have too much fuel entering the combustion chamber. Beyond that I would only be guessing the reason (air fuel mixture regulator, worn jet, wrong size jet, something else bocking air flow etc.)
Dec 26, 2012 | Generac Power Systems Generac 5525 20 Kw...
Quatz watch not running even when i put a new battery in
Several things could have caused this. First if the battery was not installed properly or by a trained technician the movement may have been damaged. We see this all the time with watches taken to the 'Mart' stores or to Jewelers and the little places at the mall. None of these places have trained personnel and they damage a lot of watches.
The other possibility is that the lubricants in the movement have dried out and are now gummy and act like glue holding the gear train in place so the power from the battery cannot get it to move.
Both of these problems require professional help. A watchmaker can repair either of these situations.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 20, 2010 | Watches
Sony PSP Console switch on and off by itself. When swithing on, even with power cable and battery full it switch off after a few seconds. What can be the problem and how can i fix it.
Please take it to a Sony center as this is an internal hardware problem. A certified Sony personnel should be able to look at it and fix it.
Regards
Feb 22, 2010 | Sony PlayStation Portable (PSP) Console
Water pump problem
Very old, that. Could be sucking air along the line. Or internal leakage due to wear. Better contact trained personnel.
Jun 25, 2009 | Garden
Internal battery
Below picture is exploded view how to change back-up Lithium battery in Sony GV-D900 player.
Hope it will help you out.
Sep 12, 2008 | Sony GV-D900 Mini DV VCR
Sony NV-U73T GPS Receiver Logo
363 people viewed this question
Top Sony GPS Experts
Will Halftowaite
Naveen Sistla
Naveen Sistla
Level 1 Expert
Steve
Are you a Sony GPS Expert? Answer questions, earn points and help others
