Question about GE Dryers
Electric dryer rotates when i hold starter down. sometimes we have to rotate the drum hand first to get it to run
  • GE Master
  • 909 Answers
You have a faulty capacitor. normally found on or close to the actual motor. Replace it. Keep to exact value.Normally 8 microfarad.
Posted on Jun 06, 2010
When I push the start button, the dryer does not come on, but it just hums.
Check to see if you can rotate the drum. if you cant then you need to check the blower wheel. If you can then hold the door switch in and start the dryer. if it starts to hum rotate the drum while holding the door switch in. if it runs on it own after you rotate it then you need a new motor
Jul 12, 2011 | Kenmore 600 6963 Electric Dryer
Runs for about 5 minutes and then shuts off
You might have a motor failing. Before you order parts, you need to check some things. Disconnect the electrical power from the dryer. Two spring clips hold the top down on your dryer. Insert a putty knife or a small screwdriver into the crack between the cabinet and the top. About 2-3 inches in from each side is a spring clip. Push in on the clips and they will release the top from the cabinet. Lift the top and let it rest against the wall behind the dryer.
Rotate the drum slowly by hand and listen and feel for hard places. The drum should turn smoothly and fairly easily. You will be turning the motor and the blower wheel as you rotate the drum and if something is inside the blower housing you should hear it rubbing or moving around.
If nothing is wrong in the blower wheel or the drum bearings, the motor will be your problem.
Jan 13, 2011 | Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Mar 25, 2010 | Zanussi TC7102W Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
START SWITCH HUMS BUT THE DRUM DOES NOT ROTATE
Try turning the drum while holding down the start button the belt could be twisted
May 10, 2009 | General Electric DHDSR46EGWW Dryer
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
Kenmore electric dryer
Belt
Motor
Door switch
  • Remove the belt.
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
