Question about Intel D845GVSR Motherboard
On-Board VGA doesn't work but the APG VGA card works on the same machine, i checked all the possibilities over BIOS its all correct it gives me 2 beeps continuously
    Genius:
  • 1,121 Answers
Try updade bios on motherboard.
Posted on Jun 06, 2010
  • 85 Answers
Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Hello my hp a1330n wont power up ,has a flashing light at power cord . unhooked mother board and light stays on. what do you think?
Inspect the motherboard for loose components. A loose or missing CPU, BIOS chip, Crystal Oscillator, or Chipset chip will cause the motherboard not to function. Also check for loose or missing jumper caps, missing or loose memory chips (cache and SIMM's or DIMM's). To possibly save you hours of frustration i'll mention this here, check the BIOS Setup settings. 60% of the time this is the cause of many system failures. A quick fix is to restore the BIOS Defaults. Next, eliminate the possibility of interference by a bad or improperly set up I/O card by removing all cards except the video adapter. The system should at least power up and wait for a drive time-out. Insert the cards back into the system one at a time until the problem happens again. When the system does nothing, the problem will be with the last expansion card that was put in.
Switching power supplies (the most common used PC's), cannot be adequately field-tested with V/OHM meters. Remember: for most switching power supplies to work, a FLOPPY and at least 1 meg of memory must be present on the motherboard. If the necessary components are present on the motherboard and there is no power:
    1) check the power cable to the wall and that the wall socket is working. (You'd be surprised!)
    2) swap power supply with one that is known to work.
    3) if the system still doesn't work, check for fuses on the motherboard. If there are none, you must replace the motherboard.
If the motherboard cannot configure to a particular peripheral, don't automatically assume a bad motherboard, even if the peripheral checks out on another machine -- especially if the other machine has a different BIOS revision. Check with the board manufacturer to see if a BIOS upgrade is available. Many BIOS upgrades can be made right on the MB with a FLASH RAM program provided by the board maker. See our BIOS page for more information.
Aug 03, 2011 | HP Pavilion a1330n (EL466AA) PC Desktop
After updating bios of my sx280 from Dell i lose my dvi-signal. i have yet no signal by booting the pc. so i cannot do anything with this pc. No dvi-monitor works and no vga also doesn't work. Is there...
firstly you should be able to use a vga monitor by default no matter what you are doing. If you can borrow one from a freind or have one if you dont have any signal with vga *********** board is not booting. vga will be in rage even at it lowest settings.Does the vga say out of range. And is this a video card or is this card on the motherboard or both.
Jul 04, 2011 | Computers & Internet
2 short 6 long beeps, whats the problem? nothing on screen, no other signs.
Check your VGA Card it's properly connect and your memory module, maybe one of that is not functioning.
If still have that beeps then change temporarily your VGA Card with another. As long as you see some appears on the screen then it's good luck.
Please rate us!
Oct 05, 2009 | ASUS p4p8x-uay Motherboard
1. On board display card is not working 2. When we attach external vga card display is working but no BIOS image in mother board and it gives an error that BIOS image is scan. 3.Key board is not working.
who makes the mother board and what bios is it using? can u access the bios at boot up? if so, is the integrated video option on? have you checked for upgrades / updates for the bios ? if you can access the bios, remove all non integrated devices from the mother board, select the option for "default settings" save and exit. then restart. after assuring the keyboard is plugged in the correct port. it should be color coded.
May 19, 2009 | Gigabyte GA-K8VM800M Motherboard
Radeon 9600 (128mb) detected as sis315 vga (16mb)!!!
The SIS315 is an integrated video card which uses shared RAM in order to work. Most mainboards will automatically turn off the integrated card as soon as an AGP or PCI-e card is installed. Yours may not do this, or maybe the card just needs re-seating as it is not picking it up correctly.
First you need to double check to make sure the new card is firmly in the slot (this is a common problem that is often overlooked) re-seat card and push it firmly and evenly into the slot. Next, on start-up, go into BIOS and make sure all on-board video is disabled. Save and then restart as normal, hopefully it will see your new card and then be looking for the drivers.
It is possible that the BIOS has your on-board video set on auto, which would mean if no other card is present then the PC would automatically go back to on-board video. Which means it can't see your new card, which in turn means it is either not installed properly or it is faulty.
Just out of interest, it may seem a stupid question but you have plugged your monitor cable into your new card and not the on-board socket?
As always much more info is needed for more help
Bri
Feb 04, 2009 | Connect3D : RADEON 9600 128MB TV-out DVI...
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
Monitor doesnt switch on
Can you try another monitor?
Since you did try another video card (AGP). I posted (In you're other post), you have to make a bios adjustment under Advanced menu. Once you're P4SP-MX bios is set to boot to the AGP or set to Enable. The bios will no longer try to load the on-board VGA card. I am not being picky about the statement I am going to make ( so don't be offended). Monitor's only receive signal. They do not send signal to PC, just receive. The odds of two video cards not working is high. You did mention you have not heard P.O.S.T (A single beep), which is a test of the motherboard. There could be a loose connection in you're PC. I would remove the memory first. Clean the contacts with alcohol on a cotton swab & blow out the memory slots with canned air (allow time to dry). Than firmely reseat the memory. I would than re-check all data & power connectors within the PC, making sure all are securley connected. With respect to the AGP card, I would do the same. Remove, clean & reseat. Most older AGP's require additional power. Some use a power cable that is also used to power a floppy drive & others use a 4 pin molex (see link),
http://pinouts.ru/connector/4_pin_Molex_power_connector.shtml.
When you are in the bios & within the Advanced menu you may also need to set the bios to read you're AGP card to the correct speed. (EX: 1x,2x,4x). Page 2-19 in you're manual. Once all these checks & cleaning have been completed, try again. Boot the PC and hopefully you will see display on you're monitor.
Post here. Let me know how thing go. Don't assume anything, check all.
Luck!
Mike
May 12, 2008 | ASUS P4SP-MX Motherboard
TFT screen not working
hi
clean your vga ,fix it in your agp slot also remove dust from it .
reconnect all cable to board.also clen processor case.
clear your bios.
take away cmos cell for 15 minutes.
Mar 24, 2008 | MSI FX5200-T128 (128 MB) Graphic Card
Tyan Thunder K8HM no POST
It sounds like you?re an experienced hardware guy so I won?t bore you with the basics. When I?ve gotten stuck on a new motherboard no-booting problem these steps have helped me: -Make this as basic a machine as possible. You don?t need much of anything to get the POST to display and anything else just adds more variables. -double check the processor and memory, ensure they are correct for the board. Make sure the manual is the correct one for your board. -Try setting the BIOS to the manufacturers ?Safe? settings or default settings. You might even want to pull the backup battery out, unplug the power supply and let it set for 30 minutes to void the BIOS settings. -Verify the power supply is working correctly, preferably with a power supply tester. If you can?t then try putting this power supply in another computer to make sure it not only turns fans on but really supplies the correct voltage needed to make things work. -Buy or borrow a pre-boot test card. This is a diagnostic card that plugs into a PCI slot of your PC and will give you a much better diagnosis of what is going on. You can usually pick one up for about $35. - Make sure your CPU fan is plugged into the right motherboard connector, the newer boards will check for the CPU fan. I would suspect that if this were the case you would see something on the screen but you never know. Last but not least you might actually have a defective board. Granted it doesn?t happen too often but I?ve had two or three dead out of the box over the past few years. Chances are if you?ve gone thorough all of this and relate the steps to Tyan support they will send you a replacement. And if the new board does the same thing then you only have two remaining variables left; CPU and memory. Good luck and if you have any other questions please let us know.
Jul 10, 2007 | Tyan Thunder K8HM (S3892G3NR) Dual...
Intel Desktop Board D815EEA2
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Apr 18, 2007 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Intel D845GVSR Motherboard Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
