Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
What frequency is the ht1000 - Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
  • 56 Answers
These radios were available in many frequency ranges from VHF through 800MHz. You can decode your radio's model number to tell what band your radio should be in.
You can use this chart to decode your model number. See http://www.batlabs.com/visar.html for more information about these radios.
Posted on Jun 14, 2010
How do I find the frequency my motorola mts2000 is using
Your radio can be read out by an authorized Motorola dealer or by a company or municipality with a software subscription to that model of radio.
Best regards.
Dec 11, 2013 | Motorola HT1000, MTS2000, MTX8000/9000...
DECODING MODEL NUMBER/FREQUENCY RANGE
This is the model number for a UHF Motorola CP185. Specifically, 16-Channel, 4W Model 435-480 MHz. The only way to determine the frequencies programmed into the radio is to have the radio read-out by an authorized Motorola dealer or other entity with a subscription to the software, as well as, a radio interface box (RIB) and appropriate cable.
Best regards.
Nov 29, 2013 | Motorola HT1000, MTS2000, MTX8000/9000...
I FOUND A MOTORALA HT1000 ON THE SIDE OF THE ROAD AND IT IS PROGRAMMED FOR A COMPANY HOW DO I UN PROGRAM IT
The HT1000 is dealer programmable only. You should take the HT1000 to the nearest Motorola dealership and turn it in. It is likely they will be able to return the radio to its rightful owner.
Feb 16, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I need to get a manual for Ht1000 and ex500.
Unable to locate a PDF file for the EX500 or HT1000 online, however, here are the part numbers you can order by HKLN4118A for EX500 and 6881079C50 for HT1000.
Best regards.
Feb 10, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
If i want to use a repeater station what channel do both us need to be on eg if i am on 1 does the other person has to be on 31
Your radio needs to be programmed for one channel to duplex. Duplexing is when a channel has a different frequency for transmit than for receive. (Not all radios are capable of doing this.)
A repeater listens on one frequency and then retransmits what it hears on another frequency. See your local radio dealer for more info, and to see if your radio is repeater capable.
Oct 13, 2009 | Motorola UHF 435-470Mhz Antenna VISAR...
Is it UHF or VHF
This is a UHF radio.
SDC is 450-520 MHz.
RDC is 403-470 MHz.
As you can see the two bandsplits overlap in the common 450-470 MHz range. If your frequency is between these numbers either of the HT1000 models will work for you.
FYI: VHF has the letters KDC usually.
Jul 28, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
About mts2000 i
The MTS2000 is a dealer programmable radio, there is no way to know what is in channel 4. You would need to have the radio read-out by a dealer, the print-out from the original programming or know who the dealer was and call them.
Jun 10, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Frequency determination
The number you are looking for should start out with a "H"
Example H01UCC6DB3AN, The 4th character "U", in this case denotes 806-870mhz range.
Post back with you model #
Podge
Apr 09, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
MY RADIO
This radio needs to be reprogrammed with the Motorola programming software, this procedures needs to be made by a technitian or someone that has the software, programming cables and the knolagement and the frequencies of course, also the radio has to be the same band of the police.
Oct 26, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
601 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
