Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Outdoor timer and started to make a humming noise
The timer is a Intermatic ML88T
  • 1,363 Answers
IT COULD BE THE TERMINALS ARE LOOSE TIGHTEN ALL OF THE SCREWS THAT HOLD WIRES ON TIMER BOARD.. ANOTHER THING I WOULD CHECK IS THE AMPS YOUR MOTOR IS DRAWING , MATCH THE AMPS TO THE NAME PLATE ON YOUR MOTOR SHOULD BE RIGHT AT IT OR UNDER ... THE NAME PLATE AMPS.. SO SAY A 1HP 1.0 SF MOTOR HAS A 7.6 AMP RATING AT 23O VOLTS THAT SAME MOTOR WILL SET TO 115V CAN DRAW 15.3 AMPS .. VOLT AND AMP METERS ARE CHEAP AND A VALUABLE TOOL AROUND THE HOUSE,CAR... NOW IF' I WAS ANY HELP TO YA ALL . HIT THE RATING OR HELPED BUTTON ........... THANKS AND BE CAREFUL EVERYDAY ... JAY
Posted on Jun 10, 2010
I need instructions for setting my Malibu ML88T
Do you mean the Intermatic Malibu ML88T power pack? Intermatic has most of their manuals on their support page: http://intermaticstore.com/en/productresources/productdocumentation . Since the ML88T is a discontinued model, click on the link on the right for Discontinued Product Documentation then on the power pack link. The ML88T support page is: http://intermaticstore.com/en/productresources/discontinued_product_documentation/power_packs . The direct link to the manual is http://intermaticstore.com/en/productresources/discontinued_product_documentation/power_packs/ml88t .
I hope this helps.
Mar 20, 2017 | Malibu Hardware & Accessories
Intermatic t10004rt3 pool timer cycles a loud hum/buzz noise like bad contacts or relay
T10004R control center has one T104 240V timer, with extra space for another timer or freeze control etc.
You can clean up the timer and replace clock motor to stop most noises.
The T104M (M for mechanism-only, snaps into the control center enclosure.
The T104 also snaps out of enclosure using thumb spring located top inside box.
Take image of wires before disconnecting from timer.
The T104 is identical to WH40, same parts, same trippers, same appearance, except with different override lever.
Here are photos of WH40 showing how to take apart timer and clean it, also with links identifying replacement parts:
http://waterheatertimer.org/Photos-of-WH40-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
If you need to replace timer, it is cheaper to buy the ordinary T104 that comes inside a box and can be snapped out, instead of buying T104M (M for mechanism-only)
Gene
h
Apr 10, 2014 | Intermatic Hardware & Accessories
I have an intermatic T40404R5 which is what I believe to be a double T104 220V, 125 amps. This timer controls our pool. A couple years ago we had our pool converted to salt water and they hooked the...
Pump humming means start capacitor is bad on motor, and motor is overheating and will soon burn out unless serviced immediately. First symptom is humming, and next is tripped breaker. Overheating will melt this pump.
Timer issue probably separate, such as clock motor burned out, or overheating melted terminals inside timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
T40404R5 is fully repairable: Plastic insulator cover is 124T1952 or 124T2411A. Yes I would cover terminals so there is no possibility of high voltage arc to metal box.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Add a comment and say what you discover
Jun 02, 2013 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic model hb300rcl
Intermatic has discontinued HB300RCL timer from their stock numbers:
Copy following link to see Intermatic outdoor consumer timers;
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB300CL
Amazon carries HB300RCL timer 11-23-12:
Timer has 1 year limited warranty
There are no replacement trippers.
How to set timer:
http://waterheatertimer.org/How-to-set-timers.html
More outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Nov 12, 2012 | Intermatic Hardware & Accessories
On sa 210, when timer off (either from program or manually switched off) correct "bulb off" status is displayed on the indicator, but the power doesn't go off from the outlets. this problem...
Most digital timers can be restored by resetting timer and then reprogramming.
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
http://waterheatertimer.org/pdf/Sylvania-SA-210-Manual.pdf
Sylvania tech support: 888-548-4484
www.hardwareinnovations.com
Sylvania timer has 1 year limited warranty.
Sylvania timer can be used for 1000W incandescent Loads and Motor loads up to 1/4Hp
All outdoor timers are susceptible to power surge from nearby lightning.
Timers are also affected by line noise and incorrect outlet polarity.
Test outlet with circuit analyzer. Use timer to control different Load on different outlet.
If more than one timer has same problem, then suspect can be line noise and outlet polarity.
Heavier-duty Intermatic HB8800RCL timer has limited lifetime warranty, and controls 1800 watts and 1/3 HP.
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK/ref=pd_cp_hi_2
Aug 05, 2011 | Sylvania SA210 15 Amp Zip-Set Digital...
Can you help me troubleshoot a Intermatic Landscape Transformer - 88 watt - ML88T?
The following link carries ML series power pack troubleshooting, plus links to trippers and manuals, plus information about 5 year warranty.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment with followup question if needed.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Intermatic 24hr Outdoor Timer
Need help with timer it is making a loud humming noise but it is still tirning yard lights on and off
If its a older model the timer motor is wearing and will hum. The cold weather will make it hum even louder
Dec 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My HB31R runs slow. Is there any adjustment ability to the timer mechanism to achieve a correct 24 hour timer.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb31r.aspx
HB31R heavy duty 1800 Watt outdoor plug-in timer is one-piece unit that does not come apart for repairs.
Usually with these mechanical dial timers, when the clock motor starts getting weak, the timer dial starts to stall when tripper meets on-off lever.
And then timers runs slow.
At this point, the little plastic gears are getting stripped out, or the clock motor is overheating.
In either case, the clock motor is spiraling downward.
If this is new timer, take it back.
If this is older timer, the manual and fact sheet do not show a warranty.
New HB31R on ebay for $15
http://compare.ebay.com/like/250558888618?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=181711814537&crlp=1_263602_304662&UA=WXF%3F&GUID=c8511cb512c0a0aad3e705a7fffd84ab&itemid=250558888618&ff4=263602_304662
Woods makes 1200 Watt outdoor timer, but lighter weight than Intermatic:
http://www.amazon.com/Woods-59204-Weather-Outdoor-Repeats/dp/B0014WRNNK
With larger heavy duty outdoor timers like the Intermatic T-101R outdoor 120Volt timer, you can buy the clock motor separate and replace when clock goes bad. And you can buy the trippers separate. However T100 series timers are not plug-in, they are hard-wired. T-101 is made to last 10-15 years, but cost $60-70. My local Lowes sells them in stock for less.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Dec 08, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
294 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
