Question about Maytag Performa PAV2200
Have a maytag gas front loading dryer pyg2200AWW and the drum does not turn. From what I can read from the various posting, it seems that the belt has broken. Not sure how to tear this thing apart as most postings and not even close to what model i have can you point me to a free website to pull either manuals or get direction to do this repair.. appreciate your assistance
Have a performa dryer model #pyg2200aww the problem is it dries for the first 10 to 15 minutes and then it shuts off, if we wait for 20 minutes it starts again but then it shuts off again.
Posted on Dec 31, 2010
Maytag pyg2200aww idler pulley spring replacement
You will have to dis assembly the dryer. UNPLUG, pop the top up with a putty knife, insert between the top and front panel about 2 inches in a press the clip so the top will come up. Remove the screws on each side holding the front on, each under the drum and remove the belt , now you came remove the drum, and get to the idler pulley spring. Re Assembly is opposite of removal.
Aug 27, 2014 | Maytag Dryers
Maytag pyet244ayw---the dryer would not turn off.it had to be manually shut off. now, it turned off during a drying cycle. i can hear a whining sound when i tried to restart it.
Could be the belt.
Disconnect power.
Using a putty knife, slide it under the top and front panel of the dryer. There is one clip near each front corner. Pull up on the top panel while depressing the clips.
With the top up, you can see the drum and the belt should be around it and tight. You should be able to rotate the drum with your hand with some resistance. If the belt is not present then it is probably broken and under the drum. If this is the case, the whining you hear is the motor turning under no load.
Please post if this is the problem or if other to assist others with a siimular problem.
Dec 15, 2009 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer, model #MDG7600AWW does not turn on
a thermal fuse should read shorted until it gets hot .. the buzzing you hear might be the motor running but not turning the drum .. that would be a broken belt .. the motor is spring loaded to keep the belt tight ..the belt is long .. it goes around the drum and down to the motor ... belts are available at many appliance parts shops .. changing it is not hard for someone handy .. a bit more than you would want to handle if you are not mechanically inclined ... on some maytags the whole front of the dryer comes off with just two screws near the bottom .. that makes servicing much easier ..
Sep 12, 2009 | Maytag Dryers
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
I have a Maytag DE50 dryer and the drum belt broke. Anyone have a diagram or instructions on how to put the new belt on?
Ignore gas references if electric dryer.
Unplug dryer and shut off gas. Disconnect gas line. Tip dryer onto its front. Remove back panel. Unscrew and remove inside back manifold. Place belt around drum and fit into pulley wheel(s) on motor shaft. (There may be a spring loaded tension arm on one of the wheels. Install the belt on it so that it pulls the belt tight around the drum and pulleys.) Check friction gasket (that the drum rotates on) on manifold and replace it if worn thin. Install manifold. Install back panel. Reconnect power and gas.
Aug 11, 2009 | Dryers
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Drum makes noises as it turns
Your rollers may be bad. The drum rotates on three or four rollers. You would have to remove the front of the dryer and then pull the drum to see them. If you decide to replace them, it would be wise to get the felt kit that attaches to the drum as well. Good luck.
Apr 17, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Dryer
hi thanks for the question the belt has stretched replace the belt thanksthe appliancedoc
Sep 15, 2008 | Maytag SDG4606A Gas Dryer
Washing Machines Logo
368 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
