Question about Microsoft Windows 98 for PC
I want my original toolbar back
I changed my wireless modem and my original toolbar has dissappeared. how do i get it back? there are a lot of things missing
  • Paul Hutchinson Jun 06, 2010
    have you tried right clicking on the "item" that you want on the tool bar, and selecting the send to function and sending to the tool bar?
  • eirian137 Jun 06, 2010
    problem has been fixed. thank you
Passwodr protected
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 12, 2011 | Arris SBG1000 Wireless Cable Modem Gateway...
I would like to reset this modem reinstall motorola cd and begin with clean network and install.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 21, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How I can change the wireless paswword on a 2wirre modem
Jan 15, 2011 | 2wire (1000-400108-001) Router
Why does not the wireless connection work on my PSP?
Pull the power wire out of the back of your modem and from the back of your Router(Belkin) and wait 1 minute.
Put the power wire back in the modem and wait 1 minute
Put the power wire back in your Router(Belkin)
Restart your computer and it should work unless your internet is out due to maintenance or bad things at your ISP
click here to download repair guide.. it helps a lot
Dec 16, 2010 | Sony PlayStation Portable (PSP) Console
How do i change from having a wire to the modem to wireless
Thank you for using Fixya!
In order to go wireless you need to know if you model has wireless capability (ask your Internet provider or from who you purchase the modem). If the modem does not have that capability then get a wireless access point or wireless router (I suggest a wireless router so you can have multiple computer connected to the internet). There are lots of brands out there namely, Linksys, Netgear, D-link or Belkin.
Hope this helps.
Sincerely,
stif_nec
May 23, 2010 | 3Com OfficeConnect Wireless Router
It worked fine last nite;came home today and it wont pull up the eweb or start or anything I click on? It said at one point I was not connected to any network;now it says am connected to Netgear network. I...
There are lots of possibilities here. The first thing is IF you are connected through a wireless network, Disconnect from the network. If you are networked directly into the Comcast modem, disconnect from the cable modem. If you disconnect from the network entirely and things seem to return to normal, then it is possible that you have a cable modem problem, a wireless router problem or someone has hacked into your network. The latter is most likely if you are running a wireless router and it is unsecured as this allows others to use your wireless network without your permission. If you disconnect from the network and things seem to improve only slightly, try running a virus scan while disconnected from the network and see what pops up. If anything has been downloaded to your computer a virus scan should find it. I would also recommend going in and making sure file sharing is turned off. If things seem okay after a virus scan, then try hooking back up to the network. If everything seems okay at that point, then most likely the cable modem or router are okay. If you still have a problem after reconnecting to the network try resetting the cable modem and the router. If you continue to have problems, I would call Comcast at that point and have them help you troubleshoot the cable modem to see if there is a problem with the modem.
Jan 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
I can't change the http://192.168.1.1 to something else
you tried changing ip when the modem isn´t connected?
can´t you turn the inbuild router off from modem setting?
May 25, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Turning on PS3 causes home wireless network to stop working
I have the same problem. My router is located about 1.5 feets from the PS3 and when I turn on the console my wireless network barely works. Something I did was change the frequency of the wireless. It was working in channel 9 and now it's on channel 3 with no problem.
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Mac and Thompson router
I've run into cable modems that don't like to use ethernet sometimes. In cases like this, I have to do a soft reset of the modem and things usually work again.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the power button on the modem
  4. plug back in the power
  5. count to 30 while holding the power button (the modem should be blinking a lot)
  6. release the power button and see what happens.
Jan 14, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
