Question about Whirlpool Duet GHW9150P Front Load Washer
Maching keeps flashing F35 as the problem but there is no problem related to that number in the manual. What is our action?
  • Whirlpool Master
  • 909 Answers
Most common problem on these machines are blocked pipes or jambed drain pump motors. Being a sequential control, it will see a problem and give a digital output even though the problem was caused some where else in the program. Check the pump and pipes for problems
Posted on Jun 06, 2010
Whirlpool front load washer keeps flashing F35 code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Jan 09, 2011 | Washing Machines
Hi our washer keeps flashing f35 and will not work
One way for you to find out is to remove the bottom panel and consult your tech sheet.
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore Elite...F35 keeps flashing..what does this mean. Please help
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(&^%#
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE 5T Steam Front Loading Washer keeps flashing the code F35. What does this mean? It is not in the manual.
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have kenmore elite HE5 front loading washing machine. it keeps flashing F35 during cycle and there is no help in the manual.
Nov 22, 2009 | Kenmore Elite 45986 Front Load Washer
HE5t washing machine flashes F35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Jul 27, 2009 | Kenmore Washing Machines
Keeps flashing F35, when unplugged and plugged back in flashes SUD, there is no soap in the machine. When trying to raise / spin or drain or any other cycle keep getting F35 flashing. This is a Kenmore...
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
My whirlpool washer flashes f35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
