Question about Kohler 12 kW Emergency Power System - 12RES-L
My Kohler 11RMY (40 amp) standby generator will not start
This used generator was professionally installed at my home. The previouus owner upgraded to a much larger unit and was serviced yearly with 200 hours on it. I know the previous owner and of the reliability in previous location. Major service performed 3 months ago. Current install is without transfer switch. Understand gas pressure(s) must be present and maintained for unit to start and to remain on. Electrical to panel installed. Breakers on unit and to house off. Oil full, battery charged and tested with load. Fuses under run, auto, off toggle have been tested and are good. When toggle placed in run position, unit makes no attempt to start. Gas installers say its electrical, electrical installers says its a fuel prob. Kohler service wants $500 for expert tech to visit and diagnose. Not opposed, just looking for ideas first.Thanks in advance.
  • 3 Answers
If the engine does not turn over check for the obvious , dead battery or blown fuse or fuses on the control board.
Posted on Jan 04, 2011
    Scholar:
  • 142 Answers
You should have two wire remote Start/Stop. It may need to be shortened in order to start.
Posted on Jun 06, 2010
Can I see a copy of order?
You need to request this from whomever you purchased the generator from.
May 31, 2015 | Kohler 14RESA Home Standby Air Cooled...
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
We just installed the Kohler 20RESAL in a open air enclosure behind my clients house and when it's running it's incredibly loud. You certainly can't talk to anyone if you are standing next to it and the...
No be careful !!! the muffler is designed to give a certain engine back pressure and emissions. Changing this or piping it out can increase back pressure to dangerous levels. If you build an enclosure make sure the air flow in and out is sufficient and the hot air out does not get sucked back in as cooling air (short cycle) engine damage and fire can result !
Sep 24, 2013 | Kohler 20RESAL - 20kW Home Standby...
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
My Generator will not start up
Will it start manually? if so remote ATS issue, if not check battery
Oct 27, 2012 | Kohler 20RESAL - 20kW Home Standby...
Kohler 11rmy-q53 generator. Generator starts and runs a vew minutes and shutdowns. When dry weather it is ok. When it rains it doesn't run long before shutting down.
The first thing I would do is to clean and dry air filter. If it is a foam material you can use a warm water and a few drops of dish soap.Rinse thoroughly and let dry. I also would try a small amount of octane booster in my gas. Hope this helps you.
Nov 29, 2010 | Kohler Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Looking for shop manual for kohler 9.5kw model 11Rmy home nat gas generator
email advanced-power-technologies.com they can help you with a manual
Sep 29, 2009 | Coleman Powermate Premium Plus 6250W...
Kohler 12 kW Emergency Power System - 12RES-L Logo
860 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
