Question about Mitsubishi WS-65411 65" Rear Projection Television
None of the inputs displays video or sound. just stopped working all together. i tried to unplug for a while and re-plug. tred to restore factory settings, but still nothing. any help would be appreciated
  • kr35 Jun 07, 2010
    thank you i will check it out
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If there is no picture and/or sound then it can happen due to many reasons: To start with if there is any light blinking on the front of the unit then please post back with the no# of blinks, if the unit appears to be completely dead then it can be due to the power board which need to be checked for blown capacitors. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
  • kr35 Jun 06, 2010
    there is no blinking LED lights. I did try the self diagnosis function and got no error. How does one go about checking the capacitor board.
    thank you for your assistance
  • Rylee Smith
    Rylee Smith Jun 06, 2010
    Once you open the back of the unit you can check for the power supply board where the power cord plugs into, check for any bulged capacitors on that board. If they are then replacing them should solve the issue.
  • 10,515 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 8 more comments
  • kr35 Jun 06, 2010
    i was able to get the blinking lights like you said, but then nothing after that. i turned the tv on, checked the inputs and still nothing. After the lights went through the blinking self-diagnosis, what should i do next? Thanks for the help.
  • taran_2005
    taran_2005 Jun 06, 2010
    Thanks for your response!!
    You need to tell me the Blinking Sequence. These sequence indicate a certain probable fault. Let me know what's the blinking sequence you have observed?
    Proceed.
    Hope i helped you.
  • kr35 Jun 06, 2010
    there was one blink, followed by a short pause,then two blinks. this occurred five total times, then the LED went out.
    thanks for your help.
  • taran_2005
    This means that the system is Unable to Find any Error Code.
    Error Code Probable Cause
    12 No error detected
    22 Recovery from momentary Reset
    32 Lamp Cover open
    33 Air Filter Cover open
    34 Lamp abnormality
    35 Chassis Fan failure
    36 Exhaust (Back Cover) or Lamp Ballast Fan failure
    37 Engine (DMD or Lamp) Fan failure
    38 Excess Lamp Temperature
    39 Excess DMD Temperature
    41 Short Detected
    44 DVI Cable (between Chassis and Engine) disconnected
    When did you last replace the Lamp?
    Hope i helped you.
  • kr35 Jun 06, 2010
    i have never replaced the lamp. My digital cable is pluged into the component 2 ports and is working fine. it is Input 1, Input 2, and Input 3 that are not showing video or audio. My DVD was hooked into Input 1, my Wii was in Input 2, notinh in Input 3. Yesterday afternoon, I went to watch DVD, and nothing, but the day before it worked. Like I said, the component 2 port is working fine though.
  • taran_2005
    How old the Unit is? Which LED's are blinking ?
    Proceed.
    Hope i helped you.
  • kr35 Jun 06, 2010
    unit purchased in 2003. not sure what you mean by led's blinking. it is blink ,pause, blink blink, pause for five times. sorry if i am not understanding.
  • taran_2005
    I doubt this to be a Lamp issue. There could be a Timer LED, Power LED and so other LED's on the Unit. Let me know, which LED is ON. Is their Any other LED other than Power which is Blinking or might be ON. If Yes, name of the LED as well as Color whether it is Red, Orange or Green??
    Proceed.
    Hope i helped you.
  • kr35 Jun 06, 2010
    the only LED that is on is the green one on the front of the TV when the power is on. I have never noticed any other LED's.
  • taran_2005
    As there is No Error Code or No Specific Fault Indications, I would first try to replace the Lamp to make sure it is not at fault. If that would not resolve the Problem, then we need to use testing instruments and check the Boards.
    Proceed.
    Hope i helped you.
I have sound but no picture the menu still displays just nothing from any video inputs its a toshiba 47hl167
I am assuming you have already tried leaving it unplugged for 15 minutes and then trying to restart it. Does it work in the TV mode? I.m not sure if there is a rest button on that model. If you go to Toshiba Support there might be more info.
Apr 12, 2015 | Toshiba REGZA 47HL167 TV
Why is there sound output when using am/fm but none when playing a CD?
Internal radio problem. There are two plugs for the CD in the radio. One for input/power. The other is for output/sound. If it is an expensive radio, pull the case off, look at the CD player and find the plugs to the main board. Unplug them and plug them back in, hook up the radio and see if it works.(could be that simple) Then reassemble the case. If it factory or cheap, just replace it with an aftermarket radio. This would be cheaper than an electronic repair.
Apr 11, 2015 | 2001 Nissan Maxima
None of the video inputs are working but the audio is fine.
Hello
You just make all vidieo input options to factory setting and try.
To get it follow this.
Press the MENU button.
The main menu appears
Surf through and select the Video Menu
To select the Vodeo Menu DISPLAY==>HILIGHT==>SEELCT
To restore factory settings :- Press reset on the remote control while the Vido Menu is selected. To restore each Mode to factory settings press reset after selecting the mode to be reset.
OK
Dec 09, 2010 | Sony KP-48V90 TV
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
To reset the AV receiver to its factory defaults, turn
it on and, while holding down the [VIDEO 1] button,
press the [STANDBY/ON] button. “Clear” will
appear on the display and the AV receiver will enter
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
No video on screen
Try unplugging unit, wait then plug in and try. That may reset it. If using S video maybe you should try using the reg video input and see if that helps
Jul 08, 2008 | iLO DVDR05 DVD Recorder
Reset to factory setting
Hold stop button pressed in front of the unit, and press power on the front.
Jul 06, 2008 | Televison & Video
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
Mitsubishi WS-65411 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
