Question about Poulan Pro Gas BlowerVacuum ()
How do you remove the fan from a Poulan Pro Blower? A string got sucked into it and is now rapped around the shaft.
5 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: Poulan Pro Blower starter string
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Pls rate the answer
Kurt
Posted on Mar 28, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
  • 124 Answers
SOURCE: replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Posted on Sep 14, 2009
SOURCE: replacing pull string on poulan pro blower
Just went through this pain today. Here's how I did it. Use allen wrench with T handle to remove the shroud over the carb controls and plug. Then remove about 10 screws and split the case. Use tool that comes with the unit to remove the nut holding the impeller. Behind the impeller, use torx head to get the other bolts to remove the motor. There are two other screws on the other side that hold the motor on. Drop the motor from the case carefully. It is still attached by wires to the throttle and kill switch. Note how the throttle linkage is connected because it will come apart for sure. On the one side of the housing you are looking at the plastic cord spool with the spring unit behind it. My chord simply pulled out of the spool. It was held on with a 10mm nut and start washer (not a good design). If the chord broke, remove the remnant from the take up spool. To rewind the new chord or replace the one that pulled free, you need to wind the spring to put tension on it. Make sure the take up spool engages with the spring tang otherwise it will turn free and not tense the sprint. Once engaged with the tang, the spool should set to the bottom to be level with the metal chord guide. Turn the spool clockwise 3-4 turns until you feel it tighten. With a 2nd pair of hands, hold the tension on the spool and tread in your chord. Route the chord through the take up reel into the hole on the side. Loosen the 10mm nut with the star washer and route the end of the chord through it. Tie a simple knot in the end to prevent it from pulling through. Tighten the 10mm nut which clamps on the chord. Now, slowly, let the spring tension take up the loose chord until fully retracted. Make sure the metal chord guide fits in the slot to channel the chord properly into the take up reel. Hold the spool down and give the chord a gentle test or two. The chord should retract easily and fully. Simple as pie!!! Reverse the disassembly and you are back in business.
Posted on Apr 04, 2011
How do I remove the shaft from my trimmer
String Trimmer Drive Shaft Replacement - Poulan Pro ...
? 2:18
www.youtube.com/watch?v=A_Sv1S7r_-o
Mar 4, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the lower drive shaft on Poulan string trimmers. The .
Jul 28, 2015 | Garden
Poulan trimmer drive shaft attachment problem
Square drive on the end of the drive shaft has to line up with the drive on the output of the clutch.
Jul 07, 2014 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Aug 29, 2011 | Poulan Garden
My poulan pro trimmer has no nut on the head to remove it. it has a screw inside. how do i work that. the screwdriver wont hold it.
See page 13 of your manual here for removing the head. Please realize that the head has LEFT_HANDED threads on it (not the conventional R-handed) so you have to turn it to the RIGHT to loosen and remove it.
http://dl.owneriq.net/0/025d5114-7fc1-41e0-8faa-5205f15e8cf5.pdf
Aug 07, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Shaft heating up next to trimmer head- smoking polan pro150- and how to remove head for service
You can wrap a rag around the threaded end of the string head shaft after removing the bump knob to hold in place while turning the upper part of the string head counterclockwise to remove. Then you can do the same to remove the metal shaft adapter nut above that, exposing the flex shaft in its entirety.
Aug 14, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
New poulan pro will not start
when I bought mine. The weed eater didn't start right away so I took it back where I bought it and I had them look over it. when reading the manuel It said that it might not start right away becuse the fuel mixture needs to be adjusted on the pro prolan pp125 weed eated. so we utilized what we had around us and found a tube. adjusted it and it started right up.
May 22, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan Pro Gas BlowerVacuum () Logo
52 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
