Question about Philips SA5125/37 MP3 Player
Hi, Philips SA5125 it just freezes and i cant do anything, does
Hi, it just freezes and i cant do anything, does not matter which button i press it will not respond to anythhing i have to just let it play its self out. Then after that i can switch it back on and its ok for awhile then does it again should i reset it? Thank you.
    Problem Solver:
  • 16 Answers
UR MUM
Posted on Jun 06, 2010
My Philips SA5125 won't turn on...
You might have to use a button other than volume + in the instructions below - you can find out which button by running a Repair in the Philips Device Manager:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 01, 2009 | Philips SA3025/37 Flash MP3 Player
I CANT DOWNLOAD ANY MORE
Make sure you install the disc with the Philips Device Manager on it first (or grab the device manager from Philips' website).
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips SA5125/37 MP3 Player
Philips SA5125/37
First you should hold down the go back button on your mp3 while still holding this button, plug it into the usb port. While still holding the button open up the philip device manager, this should instantly start to repair your device. While it is repairing you can let go of the go back button
Oct 24, 2008 | Philips SA5125/37 MP3 Player
Any help??
-Tha Mp3 Doctor
Oct 05, 2008 | Philips SA5125/37 MP3 Player
Freezes on me
There is a hold switch on that player - when the hold is engaged, only the volume buttons work. Read your user's manaul for instructions on how to unengage it, but all you have to do is slide the hold switch toward the top of the player and release.
If you find that, after checking the hold switch, your player is still freezing up on you, get the latest firmware upgrade from Philips' website. www.usasupport.philips.com.
Jun 11, 2008 | Philips SA5125/37 MP3 Player
Mps3 sa51xx
If you find that the GoGear will not load the firmware upgrade, then:
1) Backup all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the upgrade
Also, if the Philips Device Manager says that your device is already updated with the latest software, then go to: www. usasupport. philips. com,and enter in your model number, SA5125/37, on the next page select SA5125/37 (not "37B"), on the next page click on software and drives, and click on Firmware Upgrade Software - this will ensure that your player really has been given the most current firmware upgrade
-Tha Mp3 Doctor
Mar 24, 2008 | Philips SA5125/37 MP3 Player
Stuck at the Go-Gear screen
Sounds like the firmware has corrupted.
Install and run the Philips Device Manager from the product CD.
Select the restore / repair option and follow the on-screen prompts.
This will re-install the firmware and format the player.
Feb 16, 2008 | Philips SA5125/37 MP3 Player
Major problem
Especially if you have Vista or Windows Media Player 11, the firmware upgrade for this device should resolve that problem. If the firmware fails to update, then perform a Repair through Philips Device Manager first, and retry the Firmware Upgrade.
1) Backup all files on the GoGear (Repair will delete all files on your GoGear)
-Tha Mp3 Doctor
Jan 28, 2008 | Philips SA5125/37 MP3 Player
My mp3 player is frozen!
there is a reset button on the back on the bottom try using that
Dec 18, 2007 | Philips SA5125/37 MP3 Player
Memory corruption
mine has the same problem its stuck at the repaired! content cleared! thing
Dec 15, 2007 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
