Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron my trinitron has a line one quarter of the way from the top horizontally,it shows a lighter part above the line and slightly darker below the line.What is causing that?
    Problem Solver:
  • 16 Answers
The problem is that the horizontal blanking pulse wont tun off during horizontal retrace period. the problem is in the IC. that process the TV signal.
Posted on Apr 25, 2008
I have a Toshiba 55L6200U that recently started showing horizontal lines that are darker on the right half of the screen and lighter on the left side. These are visible with any input or on TV and also...
Back - light problem. [CCFL lamps inside it]. Check and replace damaged CCFL lamps. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 29, 2015 | Toshiba Televison & Video
CASIO EXILIM digital camera photo resolution
The Digimax A7 Doesn't work outdoors, because on top of the camera, try taking a picture, but hold your hand on the top of your camera (Cover it) it's light sensitive. On top their is a built in sensor, the Darker it is the darker the picture is, the lighter, the lighter. If you cover it, (Usually on top) It should work fine outdoor, just don' t cover it indoor. Hope this helped. -CA
Jul 14, 2008 | Samsung Digimax A7 Digital Camera
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No Color image - B&W image is distorted
it could actually be the cable box itself or there could be corossion on the cable connection outside
Dec 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Small annoyance with HP P1100 monitor. Slightly darker vertical lines.
Sounds like dried out electrolytic caps. How old is the monitor ?
Dec 19, 2006 | HP P1100 21" CRT Monitor
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
