Question about John Deere Garden
John deere LR135 engine runs erratically - John Deere Garden
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 445 with 22 hp kawasoki engine wont run
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Posted on Nov 14, 2009
  • 17 Answers
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 3320 starts up,engine runs,pto works
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Posted on Feb 17, 2010
I have a John Deere Gator 825i that that starts hard and once it does start it smokes for a few seconds then it runs clear after that. The engine does not use any significant amount of oil either.
They have a throttle body fuel injected engine. If its hard starting then smokes usually that indicates pour fuel quality or something wrong with fuel system.
Nov 07, 2017 | John Deere Garden
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
John deere lr135 how can i find a mannual for the said mower
http://lawnandgarden.manualsonline.com/manuals/mfg/john_deere/john_deere_lawn_mower_product_list.html
May 17, 2014 | Garden
My John Deere STX 38 hydro tractor starts, but it stops running after 2 or 3 seconds.
A couple of things to look for ....
The STX38 has a 12.5HP Kohler Command engine, being model CV12.5. Basically just a "throttle restricted" version of the CV14 which is 14HP, and the CV15 and CV16. All were notorious for experiencing Ignition Module problems which may manifest as any (or more) of the following ...
Erratic running & backfiring due to ignition timing out of control.
Popping back thru intake (also due to timing all over the place).
Engine cutting out after start-up.
A switched-on John Deere dealership will know about this and likely keep a replacement ignition module on the shelf, coz it's a good quick fix.
Another cause for your problem may simply be a fuel problem. 01. Look for inoperative Afterfire Solenoid (on the bottom of the carby bowl). Put your hand on it and switch the key on & off .. you should feel/hear the solenoid click.
02. Blocked fuel line filter.
03. Dirt, or debris, or water/moisture in the carburettor.
Hope this helps.
(ignition module is both the ignition coil AND the electronic trigger module integrated into a single sealed, un-serviceable unit)
Oct 30, 2013 | John Deere Garden
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Sep 07, 2009 | Garden
Garden Logo
149 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
