Question about Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum
No wate coming out the dispeser
Was working last night went to use it this morning and no water came out. Ice dispenser is working ok. would it be a case i need to replace filter its 6 months old now
  • 909 Answers
The plastic water resivoir in the fridge compartment is frozen. Need to locate the resivoir which is at the bottom of the fridge and by using a hairdrier, warm the plastic resivoir for about 6 minuites. Suggest you turn the fridge off while doing this. retry and dispence water.
Posted on Jun 06, 2010
The ice maker is making ice but when we push the dispeser from the outside it only shoots out water and no ice. What is the problem?
your dispenser will only do one or the other??... I my be wrong, but I have never seen one dispense water and ice at the same time???
Jul 11, 2017 | Refrigerators
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Aid KSCS23FVMK less than a week old had the waterline installed two days ago. Everything was working well (except it seemed that the ice took forever to be made) until this morning when no water...
Slow water and ice, could mean that you haven't gotten all the air out of your system yet. I would suggest holding the lever down for water for quite some time to evacuate the air out. If I am right eventually water will start flowing.
Jul 01, 2011 | Refrigerators
The water dispenser and ice maker have stopped working
I would recommend to check the water shut off valves at the wall (behind the refrigerator) and under the sink before you call a plumber.
Aug 11, 2009 | Refrigerators
Water dispenser not working
There are two electric valves for your ice maker One for water to make ice and the other is for your water dispenser. They can get clugged and will not dispense water. The two valves are sold together for $50 and they are right in the back of your Refrigertor where the water pipe ends. Hard water can clugg those tiny valves
good luck
Jul 31, 2009 | Refrigerators
No agua !
you would have to start with the water supply.
check if you have water coming to the fridge.
close the tap going to the fridge, open the line to the solenoids and open the tap. if there is water then supply is ok.
next check if there is power going to the water solenoid . ( this is different from ice maker solenoid) be sure to know which one.
press the dispenser, there should be power to the solenoid and solenoid should click open. if there is none, electrical problem is present.
last thing to check is the micro switch in the dispenser.
it should have contact when you press the dispenser.
tnx 4 using fixya,
drcool
Oct 29, 2008 | Samsung RS2534 Side by Side Refrigerator
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum Logo
140 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
