Question about GE GBS18HBR Bottom Freezer Refrigerator
I own a GE Refrigerator model#GBS18HBRAWW Bottom
I own a GE Refrigerator model#GBS18HBRAWW Bottom Freezer. It is 5 years old. The first time it broke the repairman said to unplug it for 24 hours. I did. The 2 weeks later it froze up again. The GE repairman came and told me I didn't leave it unplugged long enough. I left it unplugged for 5 days. 2 weeks later when it froze up again, i called GE and they were going to send out a repairman (they were going to charge me again for a service call), I told them I had done some research on the internet and apparently there is a problem with the defrost thermometer. So, I asked the repairman what the # of the thermometer was, he told me and I ordered it myself and had an electrician install it. Once again, the refrigerator froze up and now sits in my kitchen not working. Any suggestions?
  • GE Master
  • 909 Answers
You are dealing with a reasonably technical problem that requires proper expertise.(testing equiptment). S.A frica fridges are a little different to yours but in effect all the same manner of function. Right, if this icing up continues, yes there is a defrost issue. Firstly with the unit totally defrosted, and unplugged, remove freezer panel untill you get to the "evaporator." ( question is"do you have a fully electronic fridge with a digital display, or a defrost timer type fridge.)Im taking it to be a mechanical timer type.) With panel off, look on the righ hand side of the evaporator. There will be 3 important components that are imperrative to the defrost. One) Is the defrost element faulty or not?Should read about 1.6 K.Ohms. a soft heat. If so good. Two)There will be a round component attatched to the evaporator.and has 2 wires comming out of it.(normally Red or Brown).It is called a clixon. Replace it. Next three) you will see a thin plastic tube usually attached to the evaporator by small cable straps. This is called a thermal fuse. Replace it. Normally this thermal fuse will open circuit if the clixon goes faulty. Once replaced, system will definately work correctly again.
If electronic type, let me know so i can direct you through that one.
Posted on Jun 06, 2010
    President:
  • 2,468 Answers
If you mean the freezer froze up and you replaced the defrost thermostat in the freezer,then you need to check the continuity of the defrost heater assembly located on or under the evaporator coil for continuity(completed circuit) with at least one of the leads to it disconnected,if this shows good,then you need a new defrost timer,be it an adaptive or timer type,last but not least it could be a bad connection and this circuit could be losing power and needs to be checked,but this is very rare
Ge profile frige does not run but still lights up. both fresh and freezer not cooling. 5 years old. controller inside fresh does not work or light up.
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug the internal overload inside the compressor will be damaged.
Your refrigerator has a control board located on back behind a cover that is tightened in place with sheet metal screws. With the refrigerator unplugged I want you to open the cover and examine each side of the board for burn marks or loose solder connections. IF you are not comfortable to do it. its time for the fridge to be service and replace burn our parts.
Jan 19, 2011 | GE PDS22MIS Bottom Freezer Refrigerator
The GE Profile PDS22sfsarss is now 4 1/2 years old. One year ago, the temperature panel stopped working and a repair person told me to just order that circuit -- which I did and replaced it myself....
Not certain this will help your situation, but here is what I did to mine.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which probably reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 11, 2017 | GE Profile PDS20SFS Bottom Freezer...
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
GE GBS18HBRAWW / ICE BUILD UP IN DRAIN LINE/TROUGH
Check for a blockage around the through area from the freezer to the refrig. or something such as a jug of milk that you keep in the same loacation time after time. if this jug or what ever stays in this area that can cause a cold spot and keep that area from getting warm enough to let ice thaw.
Feb 10, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GBS18HBR Bottom Freezer Refrigerator Logo
588 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
