Question about Kenmore Dishwashers
I have a six-month only dishwasher and no water is going into the dishwasher.
  • 10,515 Answers
If there's no water entering your dishwasher, check these:
1. Water-inlet valve
2. Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Note - If the Machine is Under Warranty, it is advisable to Call the Manufacturer as the above Procedure might Void the Warranty, if any.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 06, 2010
The white film on EVERYTHING!! Is it the dishwasher or detergent?? Stock # 16755 Model # 16755690 Serial # FB4911984. We use Cascade...phosphate-free....dishwasher soap.
It may be the detergent, I would try changing to "Finish Powerball Tabs" Hope that takes care of your problem. Also if the dishwaser has film on inside you can buy some "Tang" and run it through a cycle that will help clean off the film. We have really hard water and I run Tang through dishwasher about once every six months.
Mar 25, 2011 | Dishwashers
Funny sound while operating
This happens some times. some times the dishes move due to water pressure!
Reorient the dishes and observe.
May 20, 2010 | Frigidaire 24 in. PLD2850 Built-in...
For over six months our dishes (especially glass and china) aare covered in a gritty, darkish material. We often have to rewqsh or hand-wah these items afterwards. We have tried numerous rinse additives,...
i would guess that you run out of hot water in your house pretty quickly. if so, your water heater tank needs drained. hook a hose to the bottom outlet on the tank. shut off the cold water supply to the tank. open up the hot water on a nearby sink. drain the tank into a sump or a drain or a bucket that is lower than the tank. it will cost you 40 or 50 gallons of water, but it should clear up the sediment that you see floating in your hot water supply. you might have to do it twice. good luck
Nov 01, 2009 | Dishwashers
Dirty dishes
I suspect that the washer arm is stuck or not turning, Make sure it turns freely. It should have a warranty, if it is new, have Frigidaire fix it or replace it
Sep 04, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Water comes in but does not wash the dishes no pressure
It could be a few problems, first of all does the water circulate at all, if not then you most likely have one of two problems, it is either a plugged pump, or the washer arm in the bottom of the dishwasher is plugged, first take the arm loose by turning the big nut at the bottom of it loose and take it too the sink and wash it out as best you can......reinstall the arm, try the dishwasher, if it still does not work, then you have too remove the pump under the washer and clean it out, also you should be running a dishwasher cleaner every six months..........you can purchase this at any grocery store, walmart, kmart, in the dishwasher isle...........hope this helps.
May 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Sep 16, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Cloudy residue left on dishes, especially seen on glasses
They are called "rinse agents". Another brand is "Jet Dry". These chemicals cause water to be more slippery and sheet off your dishes, rather than stick as droplets. Some websites suggest you can use plain vinegar as an alternative, particularly if you are battling hard water.
Feb 21, 2007 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
16 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
