Question about Home
6 year-old shower drain has strong odor. Had septic drained, did not resolve issue. Master shower used several times a day.
  • 2,841 Answers
If you are smelling an odor from the shower then I would suspect there is no trap under the shower. Without a trap you will always have an odor. So, are you 100% sure there is a trap. Another possibility is that the trap is leaking. Once the water barrier in the trap leaks out, you will have an odor. Check the trap for leaks and to maker sure there is one.
Posted on Jun 06, 2010
Crook well council says all water from shower and kitchen is septic and could contain facial matter and have to be connected to septic tank thanks george
So, you need to call a septic company and plumbing service to connect both kitchen and shower drains to septic tank.
Jun 17, 2015 | Plumbing
Septic Tank Drain Field
In numerous septic system, waste from toilets, bowls, showers, showers, floor drains and bowls courses through a labyrinth of funneling out to your septic tank or cesspit. The septic tank is typically framed of concrete or gum in more up to date plans with either apertures inside of the tank itself or downstream in the channel or field lines on the surge side of the septic system. Restrictions prevent the waste layer from leaving the tank and compacting the drain ranges. TG Wastewater
Mar 19, 2015 | Plumbing
Shower in basement is backed up. Wondering if it's because a floor drain is covered up.
sounds more like the drain line is clogged between the shower and the main stack, and shares venting and drain with your kitchen sink. Have a plumber run a drain snake down from your kitchen drain (after the 'P' trap ) to clear the line. A covered over floor drain should have no effect on the back-up.
Oct 31, 2014 | Plumbing
Septic tank drain field
dig trench
lay gravel
lay perforated pipe
lay red paper over pipe
add more gravel
cover with dirt
Aug 13, 2014 | Water Heaters
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Apr 03, 2014 | Maax Breeze: One Piece Round Shower...
Toilet bubbles when tub drains could be from stuck toy in tub overflow?
The bubbling sounds like it's trying to get the air it needs to drain. Kind of like holding your finger over thr the top of a drinking straw and then lifting it out of the water. The water won't drain out until you lift your finger off the straw, allowing air to come in so the water can drain out. If the vent is clogged it could cause this. Squirrels dropped walnuts down mine and clogged it. The vent is the pipe that goes up through the roof, nearest to the toilet and shower. If the shower drain vent line is clogged it is possible that it could be sucking the air it needs through the toilet, sometimes actualling pulling the water out of the toilet. This is not very common but it can happen. If you can get on the roof and get a garden hose into the vent line(s), you can tell if it is clogged because water won't drain, it will come back out. You should be able to turn the water on full blast and it will drain normally if the vent is clear. It's possible that there is a connection between the toys and your problem, and the way you access that drain line is usually thru the wall on the opposite side of the shower controls/drain. I would start by running water down the vent lines on the roof. Good luck.
May 02, 2012 | Home
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
We live in a mobile home, and whenever i do laundry thos terrible stench like seafood smell shows up in the hall. there is no leak under the trailer, is it something in the pipes that i can pour in the...
In mobile homes you have one drain pipe out. old water in the pipes can make a sludge and after a day or two can smell. My shower drain is open and i can smell the water when my washer drains too. White vinegar helps. Or if you have a septic tank your drain field may be clogged up and backing up into your pipes where they slowly drain.might be time for pumping your septic tank.
Sep 19, 2009 | Washing Machines
Strong plastic odor in West Bend coffeemaker
oh yes. This must be a new machine. I would recommend pouring and draining boiling water in the maker several times. You can also use vinegar, but again it has to be rinsed and refilled and rinsed again with boiling hot water.
Jun 11, 2009 | West Bend 56860 10-Cup Coffee Maker
Home Logo
210 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
