Toshiba 55H70 55" Rear Projection Television Logo
Posted on Jun 06, 2010
Remote sensor on tv stopped working on my toshiba cinema series 65 inch
2 Related Answers
bshldn
Loretta Northcutt
  • 736 Answers
  • Posted on Jul 28, 2010
SOURCE: my verizon fios remote
I can advise some basic remote troubleshooting. Try this first:
Turn off and unplug your television. Take the batteries out of the remote control that came with the television. Aim it at the remote sensor. Press and hold down the power button for 30 seconds. Press and release every button on the remote control twice. Plug the television back in and power it on. Put the batteries back in the remote control. Attempt to adjust the volume + and -. If this doesn't work try these steps.
Replace batteries in the remote control, gently with a microfiber cleaning cloth, wipe the IR sensor. You may want to lightly dampen the cloth with a light mist from a spray bottle.
Cover the ir sensor with a piece of electrical tape.
Look at your television's environment. What type of environmental interferences are there such as alarm system, other items in the room that function with remotes, (remote controlled fans, remote controlled lights, DVD/DVR/Cable Box/Satellite Box, Stereo), fluorescent lighting (includes the energy saving CFL bulbs), sunlight, smart house (sensor controlled lights and heat) or power lines by the house. Move sources (DVD/DVR/Cable Box/Satellite Box, Stereo) to another area of the room, not in the same IR path of the set.
Compact Fluorescent Light (CFL) bulbs are known to emit certain amounts of infra red radiation that can potentially interfere with electronic devices that use IR remote controls. Using CFL bulbs in sockets connected to a dimmer can result in occasional “pulsing” of light, even when the light switch is turned off. These IR pulses can be confused by the TV as IR commands and can potentially lock up the set. Use normal Incandescent bulbs
Move the TV away from CFL light sources
Try different CFL bulb brands. Professional Installers have recommended “Bright Effects” CFL bulbs available at Lowes for low amount of interference.
IR repeaters and some PC controlled IR transmitters can interfere, and should not be placed in or directed at the IR path of the set.
Lastly if possible move the set to a different room and see if you are still having the same problem.
If none of this applies then replace the ir sensor.
Anonymous
  • 14553 Answers
  • Posted on May 28, 2012
SOURCE: I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
Remote doesn't work
did you ask the company where you bought it ,why it was refurbished and what the problem was, try a universal remote, you might have to program in the code from the book you recieve when buying it, try all the codes for your make and model or look on the internet for a service depot and ask if they can get you a remote for your model t.v.
1helpful
1helpful
2answers
2helpful
3answers
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
18helpful
3answers
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
1helpful
2answers
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
2helpful
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
