Question about Dell Latitude C640 Notebook
Wireless problem 4 ma dell c640 laptop
Pls i wnt 2 use wireless connection on ma dell c640 laptop how do i make it possible
    Guru:
  • 868 Answers
I don't think you Dell Laptop Model ha wireless built in on it, but you have a PC card Slot where in you can Either use that slot to insert a Wireless PC card on your system to make it run wireless or use a dongle which is can be purchased from "ISP's" internet service providers, Exampl AT&T they have a usb dongle that looks like a thumb drive but is for accessing wireless signals from AT&T
check this out this is documentation for the type of Dell you have http://support.dell.com/support/edocs/systems/latc640/en/index.htm ^_^
Posted on Jun 06, 2010
    Sergeant:
  • 356 Answers
Hi. first is to verify whether you have a wireless card or not by going to the device manager from the control panel.
Expand the network adapter and check if your system came with a WLAN or wireless card. If it's a Dell True Mobile wireless card, you can download the latest driver from this link:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R69905&SystemID=LAT_PNT_P4N_C640&servicetag=&os=WW1&osl=en&deviceid=2491&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=0&libid=5&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=90951
then try connecting to your router by right-clicking the network icon from the taskbar (lower right-hand corner of your screen) then select view available networks and if you see your network there, click it and then connect.
^_^
Hi! pls. help me if there any Ram other than ddr 266 that compatible to my dell latitude c640 pls. i want to upgrade it into higshest
Go here and see your options:
http://www.crucial.com/store/listparts.aspx?model=Latitude%20C640%20Series&Cat=RAM
This site is your best choice for support, price and quality.
Aug 11, 2011 | Dell Latitude C640 Intel Pentium 4-M...
Remove or reset dell latitude c640 bios password
How to reset The Latitude C640 Bios password?!
1.First flip your laptop over and remove the battery, as well as any cables connected to the laptop.
2.Remove the screw latched into the memory panel on the bottom of the computer found near the rear.
3.Lift the panel off and expose the memory modules.
4.Seek for a small push-button and press it, holding it for about two seconds. Reassemble your laptop and start it up.
Thank You!
Feb 01, 2011 | Dell LATITUDE C640, P4...
Where is the on/off wirless switch on a dell latitude c640 laptop
try to press CTRL+F2. there's no wireless switch at your dell latitude c640.
Apr 02, 2010 | Dell LATITUDE C640, P4...
How to turn on/off my wireless switch on my Dell latitude c640
First make sure the Wireless device driver is installed. Press Fn+F2 keys together. This toggles On and Off for wireless adapter. Or find a key with wireless symbol around your keyboard. Or You can go into the network connections from the control panel and enable/disable the wireless network connection.
Mar 12, 2010 | Dell LATITUDE C640, P4...
Using Pro/Wireless 2200BG with Latitude C640?
OK generally if you have the drivers and it fits in the slot than there is NO reason why it would not work. As for software, one goes to the manufacturers web site and download relevant drivers, & install.
Jan 28, 2010 | Dell Latitude C640 Notebook
One of my Dell Latitude C640 laptops cannot find or connect to the wireless network. My other one will. They do have two different wireless cards, but I've compared all settings & they seem to be the...
card is hardwere. you should instell softtwere.softwere make any device active. you can get wireless softwere,in your board cd. install it .it can work
Jul 19, 2009 | Dell Latitude C640 Notebook
Possible disk size for Dell C640
it depends on u;re BIOS ! So check u;re bios and manual ...
(for example if it supports ata-4 (ultra-ata/33) )then the limit will be 128G !
Jan 12, 2009 | Dell Latitude C640 Notebook
Dell Latitude C640 get slowly (CPU nearly 100%) when install wpc54g
Well yes and no. Yes you can uninstall the software but then you will not have any wireless connection. Unless you are going to replace it with something else.
Oct 03, 2008 | Dell Latitude C640 Notebook
Dell c640 wireless connectivity problem
hi.
That's gonna be a permissions problem in the way the wireless device was set up originally. Go to network devices, properties (of the wireless connection) and check advanced options for permissions. Also check the way the firewall was set up, and if it allows the connection you are requiring.
Good luck
Nov 17, 2007 | Dell Latitude C640 Notebook
Dell C640 wireless not working
I used Everest home edition to find the wireless drivers for my DELL C640 laptop.   The wireless card in it is an  ntel PRO/Wireless LAN 2100 3B MiniPCI Adapter (IBM). I've downloaded the wireless driver from Intel's website, here:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=944&OSFullName=Windows*+XP+Professional〈=eng&strOSs=44&submit=Go!#DRI
It's the 3rd result in that search page. If the link doesn't work, simply search for Intel® PRO/Wireless 2100 Network Connection on Intel's site.
That Dell C640 wireless driver works fine for me, I'm using the wireless card to type this :)
good luck!
Aug 17, 2007 | Dell Latitude C640 Notebook
Dell Latitude C640 Notebook Logo
188 people viewed this question
Alun Cox
