Question about Pramac GBW30P Encl Diesel Genset w/Perkins Eng
Incorrect reading on external fuel tank
The external fuel tank is almost full but is only reading 5% so is cutting out
    Scholar:
  • 142 Answers
Try to check (move up and down) the level sensor if it is really in the external tank. The flowing bowl may be flooded.
Posted on Jun 07, 2010
2005 Electra glide shuts off while going up a hill when it has half a tank or less
3 things to check out. Cheapest is to set your tripmeter when filling up. If this problem occurs after riding more than 180 miles, then the fuel gauge is probably reading incorrectly. Maximum range on full tank is around 200 miles. I haven't "walked for gas" since 1968. Second cheapest one is two is to add a water remover product (not fuel injector cleaner or other related product) to a full tank of gas. Make sure to measure the amount in proportion to your 5 gallon fuel tank to a car's fuel tank. The other is to take it to a qualified mechanic who can test the fuel pump pressure.
Jan 22, 2014 | Harley Davidson FLHTCUI Electra Glide...
CAR switches itself off when fuel is on querter tank
check the calibration of the sender unit as may actually be on empty. Find out the exact capacity of the tank and add a known amount of fuel and see where the gauge reads. For example if the tank is 60 ltrs or 20 gallons add 5 gallons and see where the gauge reads. 5 gallons in 20 gallons should read 1/4 or in your case after the engine stops should read 1/4 full. If it reads 1/2 then the sender is out.
Sep 11, 2013 | Cars & Trucks
P0452 ,P0305 aurora 3.5
P0452 means fuel tank pressure sensor circuit low pressure. Possible symptoms:
- Fuel Tank Pressure Sensor harness is open or shorted
- Fuel Tank Pressure Sensor circuit poor electrical connection
- Faulty Fuel Tank Pressure Sensor
The code 0305 means cylinder 5 misfire detected. Possible symptoms:
- Faulty spark plug 5
- Clogged or faulty fuel injector 5
- Faulty ignition coil 5
- Fuel injector 5 harness is open or shorted
- Fuel injector 5 circuit poor electrical connection
- Ignition coil 5 harness is open or shorted
- Ignition coil 5 circuit poor electrical connection
- Insufficient cylinder 5 compression
- Incorrect fuel pressure
- Intake air leak
Read more: http://engine-codes.com/p0305_pontiac.html#ixzz2d8l8VHWe
Read more: http://engine-codes.com/p0452_pontiac.html#ixzz2d8kXRa8w
Aug 27, 2013 | 2001 Pontiac Grand Am SE
Fuel guage reads incorrectly
the filterbag on your fuel pump has moved against your fuel float in the tank
Feb 11, 2013 | 2002 Ford Thunderbird
My 95 7.3 turbo runs and idels good no miss but something is holdeing it back when u push the gas I have changed the fule filter and air
Here is what my Haynes Diesel Engine Repair Manual says for a noticeable lack of power, which is what you are describing.
1. Blocked air intake
2.Incorrectly adjusted timing
3.Blocked or damaged exhaust system
4.Obstruction in fuel filter
5.Blocked fuel tank vacuum vent in fuel cap
6.Insufficient fuel supply from tank to injector pump
7.Obstruction in fuel tank filter
8. Pinched or restricted fuel return line
9. Incorrect or contaminated fuel
10.External compression leaks ( glow plugs or injectors)
11. Obstruction in injector nozzles
12.Low compression
This book has an excellent diagnosis and repair section for your engine. It's Haynes part #10330 and costs about $20. Hope this helps.
May 27, 2011 | Ford F-350 Cars & Trucks
Left petrol tank stays full, not feeding/emptying - BMW X5 4.6is
inside the tank there are 2 or 3 hoses that transfers the fuel to where the fuel pump is. check for leaky hoses.
Mar 10, 2017 | 2003 BMW 5 Series
I have Nissan Altima with incorrect guage reading
The Correct Rerpair for this to to REPLACE the FUEL LEVEL Sending UNIT. It is Located INSIDE the Fuel Tank, After Reserching this through Numerous Resources I Have Fould that it is Incorperated into the FUEL PUMP. So You can Use your Current Calibration Method or Replace Fuel PUMP. Looking at the Vehicle AGE and IF IT HAS OVER 100K Miles on it , It is Advisable for you to Replace the INTIRE UNIT. It is OBVIOUSLY Not Manditory as the Vehicle is RUNNING, But If you Wish to Have Accurate FUEL LEVEL Reading Replacment is the ONLY OPTION.
Sep 01, 2009 | 1997 Nissan.5 Altima
Fuel gauge inaccurate
Change the fuel gage sender unit in tank.its faulty.
May 30, 2009 | 2001 Jaguar S-Type
Fuel Level Gage Reads Incorrect
sending unit in tank is bad need to drop tank and install new.
Jan 01, 2009 | 1997 Volvo 850
Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
115 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
