Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
I own a RoboKleen above groung pool cleaning system. Last fall before I winterized the pool, the unit quit working. I found that the fuse had blown on the power unit. I replaced it and it blew another fuse. I then winterized the pool and forgot about it. Now I have opened the pool and remembered that I have an issue with this power unit. Do you have any advice as to repairing the power unit?
Look for a short in your motor wiring. Most likely a loose wire is touching metal somewhere inside your unit. You may consider replacing the power unit because it might be cheaper then repairing it. Click on the link below to order a replacement:
http://www.dolphinpoolcleaner.org/replacement_parts.htm
Posted on Jun 06, 2010
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
Oct 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
Intex Krystal Clear Saltwater System for 2 weeks and now unit is dead. No display at all, no function. Power is on and receptacle for house power is fine.
Possible blown interanl fuse... You are required to call Intex and submit for warranty repair if under 2 years and if you have receipt.. Otherwise, you can look up blogs on how to open unit and replace the internal fuse.. Good luck.. Here's the intex number... 1-800-234-6839
Aug 19, 2011 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater System Model CS8110 service light is on. I have cleaned the unit inside and out, reset all power connections, and no luck. It runs about and hour and then the service light...
i need a part it is the electroytic cell .it got broken when we were winterising the pool last fall. we are both handicapped and on ss and use the pool to help with the arthris and soreness in our backs .if there is any way you can help we would greatly appericate it .
thank you elbert boswell and wife judy boswell
Jun 25, 2011 | Intex Automatic Salt Water System for ...
My robokleen vac runs for a few minutes then just stops. I checked the wheels nothing is stuck in there. Any suggestions?
With these pool cleaners, there are several things that you should check. Make sure that your filter bag is not full and does not have any large debris that would hinder movement. Make sure that your impeller is not jammed or broken and check the entire drive system for objects that might have become lodged.
Aug 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
It says low flow, how can i fix it. its a Intex Automatic Salt Water System for Above Ground Saltwater Pool
After five years of using our pool each summer, we assembled it last week and I kept getting the "low flow" warning (with irritating beeping) even though the water flow was very good. I disassembled the unit and checked the flow switch, and found that the switch itself was the culprit. Here's what I did: (this is probably not recommended by Intex...) I unscrewed the main portion of the salt water purifier (the part with the digital display on top) from the base and lifted it up to expose the circuit board and wiring. All the fuses were intact and everything looked good. At the bottom of the circuit board, about an inch from the right edge is where I found the connections for the flow sensor. One was marked "flow" and the other was "grnd". I removed the plugs that run to the slow switch, closed the circuit by making a direct connection between the two plugs, and voila! No problem. I ended up cutting the wires about 1-1/2 inch from the plugs and connecting them with a wire nut, then I plugged them back in. The unit is working perfectly again.
If you attempt this, make sure the unit is unplugged and be careful when dealing with the circuit board. Don't be intimidated, it's not a high-voltage connection you are working with, you are simply closing the circuit and telling the board that the switch is closed as it would be with adequate water flow. I was comfortable making this "modification" and bypassing the flow sensor because we have several years of experience with our pool and because I clean and swap out our pump filter every day during summer, and because we know the difference between strong and weak flow just by checking the inlet and outlet ports in the pool.
I hope this helps someone! It took care of my problem. Best of luck.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
Where is the fuse on the robokleen above ground pool cleaner? We've only had ours for 1 year and it stopped working. It doesn't come on at all. At first it would come on and just move back and forth in the...
There is an online manuel at this address http://74.84.137.218/website/manuals/RK01A.pdf
There is a circuit board that needs to be reset and the manuel discribes how to do this process. Make sure you are using a ground fault outlet to plug into. If there is a fuse, but I don't think there is it would be inline on the power cord. Also check the Breaker box to make sure there is power to the recepticle.
The Pool Tech
Jul 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
Dolphin quit working
See if the Dolphin ingested acorns or leaves which may be clogging the unit.
Aug 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Intex system not giving chlorine, no errors but no green light
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
179 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
