Question about Candy Dryers
I need to replace the heating element in my Candy CIC60 but I cannot reach the wire connectors as they are inside thew machine. How do I do it?
  • johnnny_esca Jun 07, 2010
    That doesn't tell me anything, can't get to the wires from the top as the drum is in the way. Already have taken the old heater unit off
    Top Expert:
  • Candy Master
  • 76,846 Answers
Instructions Things You'll Need:
  • Hand tools: Flat Head Screwdriver, Philips screwdriver and a Spinner Handle, 1/4 in. Drive. (See Sears...)
  • For the spinner Handle, a set of sockets to fit the screws (more on that in directions)
  1. Step 1 Please unplug the dryer from the wall. I'd really like you to be here when we are done!
  2. Step 2 Remove the dryer vent hose from the back of the dryer. Typically this has a metal strap clamp. This is where that flat head screwdriver comes in handy. Loosen it and move the clamp up the length of the hose and wiggle the hose off of the fitting on the back of the dryer.
  3. Step 3 Typically the back of your modern dryer has a large panel that covers the back of the dryer. This is held in place by eight or fewer screws. These screws typically have a six sided head, they also sport a flat head or Philips head opening. I prefer using a spinner handle and an appropriate sized socket. Please choose the correct size socket, and remove all the screws around the perimeter of the panel.
  4. Step 4 Now, you will note that the panel is not coming off. Do not worry, this is normal. You will find two screws near where the electrical cord goes in. Typically only one of the these need to be removed. If you need to remove both in order to find out which one it was, no problem, just pop the "other" screw back into place.
  5. Step 5 Slide the panel off the hose clamp and...OH MY DEAR ME!!!! Look at all that dust! Yes, this would be a great time to go ahead and vacuum out the back of the dryer. You'll find enough coins in there to buy yourself a coffee.
  6. Step 6 Now you are going to find a protrusion about 9-12 inches long and about 4-6 inches wide. It is rounded at one and, and squared off at the other. This is the unit that holds the heating element. As you can see it is held in place by yet more screws. Typically there two to four screws.
  7. Step 7 Once the unit is free of the machine, start to disconnect the wire that are tethering it to the machine. They can typically be wiggled off by using the flat head screw driver. flip the unit over, and there, on the belly of the unit is the heating element. Remove the two to three screws holding in place and replace it with the new unit.
  8. Step 8 To put everything back, just reverse each step until it looks like a dryer again.
Posted on Jun 07, 2010
    This does't help much, it is a generic answer to a specific question about this particular model. I have removed the heating element and before I buy another I have to be certain I can connect it. The wires are in the machine, I cannot see or touch the wires. They are not long enough to go through the access hole in the back of the machine. Are you familiar with this model?
  • yadayada
    yadayada Jun 07, 2010
    then u will need to remove the dryer drum if u can't get at the wires, remember i am not there so trying to visualize what it is you are doing can be challenging, to remove the dryer drum remove the door of the dryer and pry up the top, remove all exposed screws and it slides out, it is best if you have a helper. see if the instructions at the link below help. these instructions are good for 95% of manufacturers
    http://repair2000.com/wpoolbelt.htm
  • 10,865 Answers
Hello. pull the machine out from the wall, unplug it. Pop up the top of the machine and even remove the outer sheet metal if u need to. J.
Posted on Jun 06, 2010
My Candy CIC60 dryer works fine till my homes fuse box cuts off power. Longest it worked plugged in was less than minute. House is new built, so i don't think problem is there. Dryer is used for 2yrs.
  • Do not risk a house fire!
Candy CIC60 User Instructions
If all else fails, read the above.
Hummmm....
An Electrician might be needed. If you house is under warranty, you should read the fine print. Here is why.
It is possible that the breaker and/or wiring is under rated or defective. Check the amp draw rating on the breaker an compare it to the requirements of the drier. Installation / Operation link above If the drier is using the full amount of the breaker it will eventually weaken and fail to hold the load for as long as it did when new.
An experienced electrician will be able to determine if this is the case. Actual current draw should be measured while drier is in operation.
Replacing the breaker with a new one should fix it in that case.
Worst case would be that the wiring and the breaker are not of sufficient size to handle the load. This would be a HOUSE FIRE RISK as the wire is acting as a heating element. Again an electrician can make this determination by measuring the voltage drop of the wire from breaker to drier.
In the instructions included above, there is a phone number to the Manufacturer.
  • good luck!
Oct 04, 2016 | Candy Dryers
How do u remove the 2 wires from the heater element?
disconnect power before doing anything. in the case of no convenient means of disconnecting the wire, i see no problems with cutting the wires and reconnecting using butt splices for the proper guage wire. place your splices strategically so that they are easy to reach but out of the way of any excessive heat or moving parts. you probably should wrap the spices with electrical tape to avoid a short circuit and always work with the power disconnected. i have used this method many times on many applications with no problems.
Jun 04, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Candy cic60
your element
Mar 28, 2014 | Dryers
My econofloss 3017SS is not heating
The most common cause to a not heating problem is that the heat ribbon is installed wrong. If it was recently replaced, the 2 wire terminals need to be connected to the 2 different buss strips in the head. If both are attached to the same one, then nothing happens.
2. If this is not the problem, then inspect the brushes and slip rings in the lower spinner head. Remove the access covers and see that the brushes are tight against a shiny smooth Brass slip ring. it is common for brushes to get stuck in holders and stop contacting rings.
3.last item is the heat control.
These are pretty advanced repairs, and should be attempted by a service technician with assistance from a Gold Medal service person.
Feb 06, 2014 | Gold Medal Products Gold Medal Econo Floss...
Candy cic60
check power supply, outlet both sides voltage, cord for continuity, junction where cord attaches to machine. If there are no faults found here then element is most likely bad," it can be tested for continuity to verify before removing.
Apr 26, 2009 | Dryers
Candy CMD146 Washer Dryer drum spins but does not heat
Yes it could be the heating element. However, it could be the thermal overload switch. This is located under the top of the machine. Bypass it to see if works. If it does, then it is the switch. If not, check the element. It sounds like this is the element with the 2 yellow wires.You will need to pull it to visually check to see if it is burned in 2.Check the element first since you have easier access to it. Let me know how this works.
Jan 27, 2009 | Candy Dryers
Error code A04
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + 1 minute First, open the door and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the front panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced
Each terminal is secured with a lock nut, use a crescent wrench or pliers to loosen the nut. Remove the two lock nuts. From inside the tub, lift the element out. Position the new element over the holes and set it in place. Replace the lock nuts and reattach the wires. Replace the access panel, the element cover, if any, and restore the electricity.
Aug 31, 2008 | Dishwashers
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Apr 18, 2008 | Candy DQW150 Front Load Washer / Dryer
Cic60 candy tumble dryer
Generally, these units are gotten into from the back panel. Be sure to disconnect the power. There are two breakers linked together.
Dec 15, 2007 | Candy CDC266 Dryer
Dryers Logo
47 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
