Cd rom drive and cd burner drive accidently removed
Installed more memory. computer cannot detect either drive. system info says cd rom and cd burner dissappeared from system without first being prepared for removal. did not want to remove these devices and dont know how it happened. really need help on how to fix this problem.
IF I'M NOT MISTAKEN, UR GOING TO HAVE TO GO TO START THEN GO TO CONTROL PANEL AND UNINSTALL OR REMOVE THE INFORMATION WHERE IT SAYS ADD OR REMOVE PROGRAMS; THEN U WILL HAVE TO RE-DOWNLOAD UR CD'S AGAIN...HOPE THIS HELPS
Posted on Apr 10, 2008
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Not sure what OS you have, have you tried removing the drive in the device manager, and then restarting your machine to see if your OS reports new hardware? Or have you tried removing the new memory and restarting the system to see if you problem goes away? I might try this first.
Was anything else attempted or unplugged when installing the new memory?
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
I went to burn a cd and it says my burner or software is not found
Remove the device in device manager and re-boot the computer and let it detect and install the drivers again. This usually fixes the problem unless the drive itself is bad.
Sep 29, 2010 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
My HP DVD1040r writer that came with my Dell dimnension B110 won't burn CD or DVD's. I did a fresh install of XP Pro SP3. I need the installation setup Cd that came with the drive, but I don't have it. HP...
hi.. click on my computer.. properties.. hardware.. device manager.. select CD/DVD Rom.. (it would be in a Yellow Exclamation Mark).. doubleclick on it.. then select the option that says.. Driver Details.. and then Update Driver.. try to select options detect the driver online.. it will automatically detect the driver and try to search for it online..
or use the Product number of ur HP comp.. i.e., the one ending with #ABA.. go to www.support.hp.com.. and enter the numbers before the # sign.. and search for Drivers CD/DVD Rom..
May 04, 2010 | HP LightScribe dvd640i (DVD640I)...
DVD-RW burn drive is being recognized as CD-rom drive; it's not the laser, because I went through the trouble of purchasing a brand new DVD burner drive and it's doing the same exact thing. Can anybody...
If you have not done so, under device manager, remove the dvd rom (cd-rom) from the hardware list, Use the CD install disk that come with your DVD-ROM, install the drivers and software, then reboot your pc and let it install the new hardware detected. This should get you going.
Good Luck
C2Solutions
Aug 18, 2009 | Computers & Internet
Media player cannot detect burner anymore
Check the Manufacturer's website for a Download of the CD Drive Drivers. If you have a Software recovery application on your computer (Many HP and Dell Computers have this) the drivers may already be on your system, you may just need to re-install them. If re-installing the driver's doesn't work, I don't know what to tell you, unless your drive has gone bad.
Jun 19, 2009 | Compaq (249666-001) CD-RW/DVD-ROM (Combo)...
Samsung cd/dvd combo drive problem
Check you'r jumpers ei master slave. and all cables are hooked up right, power hook up are fully in. you may have to up date win xp. sp 2-3 so on. enter cotroll panel. system. hardware tab. device manager. look under dvd/cd-rom drivers if they are listed there 1st try to update the drivers. if that don't work then uninstall all of the dvd/cd roms listed there. then restart you'r computer. on the re start win xp install wis. shold find the roms and install them and update them. if that don't work you'll have to call the microsoft free help line. this is what they had me do when I had the same problem. you may in the end have to wipe and re install window, sorry to say. hope this helps you
Mar 19, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
LG GH20
did you get and cd along with the drive from where you bought it ??
try to see in that ..the driver must be surely present there....
btw what is the operating system you are running on your dell...most of the operating system automatically detects any hardware changes....
just also see in bios whether your drive is detected at start up.
Sep 14, 2008 | LG (GH20NS) DVD±RW Dual Layer Burner
Dvd-rom icon missing
(1) Check bios for detection if detected continue the following steps else DVD is gone or you can remove test it in other system.
(2) You can manually DVD from control panel by clicking add new hardware wizard, continue the step.
(3) last option try install your operating system agin.
Apr 19, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Issues with my cd/dvd drive
Go into the bios and see if it has the drive detected,
if dell go in get out and save.
Mar 19, 2008 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Cdrom not detecting
attach another drive to your system boot your system with bootable windows cd and make your system drive c
install windows in c drive
this problem is incounter
when u install the window in other drive than c
Dec 22, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
