Question about Zenith L17W36 17'' LCD Flat-Panel HDTV (Silver)
Picture won't expand to full screen
I cannot get the picture to go full screen on my monitor since purpurchasing a new computer. It has black border around picture 1 1/4 in on the right 1/2 in top and bottom and varies from 1/4 inch on the left to picture moving off the desktop and not visible.
I cannot adjust it with computer settings or use of monitor controls. Do I need software to re-program? What do I do
Thanks.
  • 31 Answers
SOURCE: desktop shrank and i can't get it to expand to the
Right click your mouse button on the desktop and choose properties. Then click on settings and then resize you resolution I like 1024 by 768
Good Luck
Proteus
Posted on Nov 23, 2009
techman
  • 3130 Answers
SOURCE: Bad picture on tv
You should have the Picture tube checked by a professional, as thats the first thig most peeps think that goes bad when a picture is gone or bad. It could also be the crt driver circuit.
Posted on Sep 06, 2006
scott201201
  • 170 Answers
SOURCE: Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Posted on Jul 22, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Zenith picture problems
Your TV is showing signs of age. It's displaying something called "vertical foldover" which is due to capacitors in the set's vertical output section that need to be replaced. These failed parts can stress the vertical output integrated circuit, and if that goes bad your picture will collapse to a thin horizontal line. The capacitors themselves (usually 3 or 4 need to be replaced) are pretty cheap. A TV shop in your area (if there are any still around!) could fix it and the repair should be under $100.
By moving those rings on the tube's neck (which is actually the back) you have messed up the set's convergence. Those rings are magnets which adjust the electron beams in the tube so the red, green and blue images line up correctly on the tube face. The rings are often marked with a stripe after adjustment to show how they were lined up. Look carefully at them and see if there are any marks you can go by to reset them. To properly converge the set some equipment is needed to generate the adjustment test pattern. Again, a shop could do it for you.
All things considered, at this point you might seriously consider replacing the set. Not because the troubles aren't fixable, but because other parts can start failing because of age, and by now your picture tube is on borrowed time as well.
Posted on Apr 22, 2009
jomabug76
  • 1148 Answers
SOURCE: display smaller than screen capability
GO TO CONTROL PANEL ,,DISPLAY OPTIONS,,, CHANGE YOU RESOLUTION
Posted on May 15, 2009
Hcl moniter screen adjust problem
hi. this may be from EEPROM IC. you can program it or replace IC with new one and then program it.
Apr 27, 2015 | Computers & Internet
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
My screen picture used to be the full size of the secreen, now there is a border on the top and bottom cutting the picture down like in the movie theatres. How do you get rid of the border and get back...
If you are using cable TV there a button on the remote "*" which zoom in and out. You can also check with your cable company in case you have HD TV and not using a HD box.
Jun 20, 2014 | LG 50" 5700 Series LED HDTV - 50LN5700
Can I get rid of borders above and below my screen when watching netfix on my pc
What's probably going on here is that the video your watching is a different aspect ratio than your monitor. So for the video to completely cover your monitor it would either need to be stretched, or have part of the video cropped off on the sides. Instead of distorting or cropping the image the black borders are shown. Netflix doesn't provide a way to change this currently. A work-around though, would be to change the resolution on your monitor. So if for example your monitor has an aspect ratio of 16:10 (like 1920x1200), and the video is 16:9 (like 1920x1080), you would change your resolution from 1920x1200 down to 1920x1080. (9/16 * 1920 = 1080)
Mar 12, 2014 | Computers & Internet
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
I have Samsung BX2250. My problem is when i set up the resolution to 1920x1080, It didn't use up all the panel's screen there are black panels around the screen. My Graphic card is a ATI HD5870. how can i...
Had the same problem too... It's because it's set to underscan. To remove the black border, right click desktop and click Catalyst Control Center. Click the Graphics tab on the upper left portion of the Catalyst and choose desktop and displays. Right click the picture of the monitor at the lower part of the screen and choose Configure. At that screen, Click the 'Scaling Options' tab and move the slider all the way right to Overscan.
Triad'Warfare [url=http://valid.canardpc.com/show_oc.php?id=1571106][img]http://valid.canardpc.com/cache/banner/1571106.png[/img][/url]
Dec 26, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Window does not expand to entire moniter
right click mouse
select Graphic Properties
select Display Settings
select Display Expansion
select Full Screen (No Border)
Mar 24, 2009 | Samsung SyncMaster 205BW LCD Monitor
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Zenith L17W36 17'' LCD Flat-Panel HDTV (Silver) Logo
270 people viewed this question
Top Zenith Computers & Internet Experts
Are you a Zenith Computer and Internet Expert? Answer questions, earn points and help others
