Question about Car Audio & Video
I want to make a custom car speaker box i have 4 10" subs 2 punch p21058 and 2 dvc 10045 ignite subs and plenty of room how what do my subs require for air,space,watts and what type of box would work best with these speakers and should i wire them to eachother or hook each speaker to amp sepretly?
  • 185 Answers
Well u can go to the subs websight i mean look at the name on the subs type that in the computer see what they say
Posted on Apr 10, 2008
I have 1 12in. 4 ohm punch dvc sub and a punch
Check crutch fields website for sub wiring detailed wiring plans
Oct 07, 2014 | Car Audio & Video
Dvc wiring diagram
need the ohms of each coil and what the amp can handle in ohms
Dec 12, 2013 | Soundstream PCS-12 Car Subwoofer
Hi i have a few questions. I have bought a dual 12 " sub box and i need 2 subs and one amp to go with it. I want intence base that will impress! I am currently looking at 2 Alpine SWR-12D4 they are...
It's been my experience,that intense and low bass comes with a price,always remember u get what u pay for,so on that note,Try to get Rockford Fosgate Competition subs with a punch 250 or 500 trust me that it is a powerful combination.and if u can afford it get a choke to put on ur subs so they will only kick bass put tweeters in the dash and mid range speakers in the door u could use a dual rca jacks to install 2 amps at once and get a punch 45 amp for the tweeters and mids.hope this was helpful
Apr 03, 2013 | Car Audio & Video
How do i wire 2 fosgate punch 10" subs to this boss iq 680.2 amp? the subs are rfd2210 hx4 and theres two subs in a separated seald box. i need to know how to phase all the vcs together
Your subs are 4 ohm dvc so lower the impedance more power from your amp. I will include a link that will show you how to wire your subs for maximum performance. I would explain it but seeing the drawing will make more sense....
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Sep 23, 2010 | Boss IQ 680.2 Car Audio Amplifier
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Feb 20, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Car Audio & Video Logo
120 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
