Question about Samsung Cameras
Camera is always shutting down even if its not low battery.
  • 1,031 Answers
This is what usually happen when the battery power is too low to drive the lens motor that results in the camera using more battery power to close the lens causing the lens to jam and shut down. you can retract the lens ,replace the batteries and also check the warranty cover for the camera if still under warranty you can return for possible replacement
Posted on Jun 06, 2010
L310 shuts off when taking pic
As soon as the camera senses the battery does not have enough power, to save a picture you take, it will shut itself down, preventing a memory error. Because if the voltage is to low, no reliable access to the memory is possible. Be aware that in extreme warm or extreme cold the battery can't produce enough power.
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work.Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Always charge the batteries together, so they have the same charge.
Never use different kind of batteries together. The best is a set not only of the same brand and capacity, but also form the same batch.
Only one poor cell can spoil al the fun, because the total voltage is quick on a critical limit, shutting the camera down.
Feb 15, 2014 | Nikon Coolpix L310
Camera can't take photos
Most of the time, when a camera asks to shut down there is a problem with the camera. Could be the lens can't come out complete or other, almost invisible things. Even the battery can be a bit low, so as soon as it wants to make the camera ready to "shoot" the voltage goes low. Lots of cameras, will go off then. If you can't find any obstruction on the lens, please charge the battery and try again.
Nov 27, 2013 | Panasonic Lumix DMC-LS70 Digital Camera
Always low battery
These cameras need good batteries. Make sure you either are using quality Alkaline batteries or NiMH rechargeable.
Also check that previous batteries did not leak and damaged terminals
Oct 30, 2013 | Casio Exilim EX-FH20 Digital Camera
My Canon S3IS shuts down during zooming. What's the solution ?
It could be the batteries running low. The mechanical zoom consumes battery power and at a certain point the camera will turn itself off. If you wait a minute and turn it back on it seems OK, until you try the zoom again. If you are using non-Canon batteries the camera doesn't always detect the battery level accurately and may flash "low battery" when there is still power remaining, or just turn itself off without warning. So I suggest changing the batteries and check that the battery terminals are not dirty or loose.
Mar 25, 2010 | Canon Cameras
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
We are in the middle of a production (Live, right now) and one of our XL1's is shutting down whenever we hit the record button.
It may be timing out. Is the camera in standby mode? If yes, put it in record and lock.
I have an XL1 and a GL1 that sometimes shuts down. Is there a tape in the camera? It will time out sometimes if there is no tape rolling. Even if I am capturing directly to a computer, I always roll a tape, just to keep the camera from timing out.
What does your battery guage read in the viewfinder? A low battery will shut you down without warning. Try running from the power adapter if you have one.
Dec 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Norcent dc-1020 will not turn on and then shuts down - lens wil not recede
That happens to me when the batteries are low. New batteries have always fixed the problem.
Dec 15, 2007 | Norcent Technologies DC-1020 Digital...
Fuji S7000 Time-out issue
I think I Had that problem too. mine also quite suddenly started showing low battery even on new ones... it seemed better with non-rechargeable types. Now the reason I'm on this site is as the lens doesn't open.
Jun 06, 2007 | Fuji FinePix S7000 Digital Camera
Cameras Logo
118 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
