Question about Vizio VW42LF 42 in. LCD HDTV
Vizio 46 inch tv. Model is VW46L. screen is dark on bottom three quarters of screen. most of darkness is on left side of screen. distinct line across screen seperating the bad area. will usually clear up after tv is on for about 2 hours.
5 Suggested Answers
  • 269 Answers
SOURCE: THe entire right half of
I am having a similar problem. Try reseating the ribbon cables being very careful with the clips that hold them. On the T-Con board. Sounds like either the Lcd panel screen itself or the t-con board.
Posted on Dec 31, 2010
DrewPalmer04
  • 325 Answers
SOURCE: i have a vizio 46
I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
This could also be the CCFL bulbs that are aging and need replacement. Those are around $20 each for a bulb
Hope this helps! Please rate :)
Posted on Mar 14, 2011
salt56
  • 373 Answers
SOURCE: vizio 1080p HDTV 46"
I'm sorry to say but the LCD panel (screen) is bad. You may be able to make it come on by hitting the back of the set with the palm of your hand. If so, then the panel is bad.
Posted on May 27, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a Vizio model E-470 - a 0 it has a grayish line across top and bottom of screen can still see TV fine accept looks like a filter grayish any ideas
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Jan 12, 2017
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Vizio display issues
I have a Vizio VW46L 46 in plasma right side of screen goes black then the whole screen starts flickering and has vertical lines on up part of screen stay for hours! Help
There are so many reasons for this fault to a Plasma display, irrespective of its brand. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Faulty display screen-shots to plasma display is given by illustrations. You can compare it to that of your TVs' and can make sure about the fault.
Oct 21, 2013 | Vizio VW46LFHDTV10A 46 in. LCD TV
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
I have a vizio 46 in lcd model # VW46L FHDTV10A and it started with the whole left side going dark and then it would get better after an hour or two. then about a week later the entire left side of the...
Mar 14, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
THe entire right half of our Vizio 46in vw46L TV has gone dark and has a motion blur problem as well. The darkness started across the top third of the screen but for the last few days it has been just the...
Oct 31, 2010 | Vizio VW46LFHDTV10A 46 in. LCD TV
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
Vizio VW42LF 42 in. LCD HDTV Logo
168 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
