Question about Dacor DMT2420SS Microwave Oven
Cannot read the touch screen & only easy minute works
We just moved in so this is a new microwave to us. Already turned the circuit breaker off and back on. The touch screen is either too dim to read or has grey lines running up and down it. The only function that works is the easy minute.
Thanks
  • Dacor Master
  • 9,098 Answers
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
You can also download the owner's manual from the page at the second link.
Posted on Nov 21, 2011
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Started tripping circuit breaker. It's on a 15 amp circuit, we bought it two years ago and it only started doing this last week. It first did this 7 minutes into cooking a frozen meal. Then four minutes, 3...
The problem could be a failing magnetron or control board. The tingle may be traceable to a faulty receptacle installation - one with a floating ground or incorrect wiring such as reversal of the hot and neutral lines. The vibrating sound seems to be one of the quirks of GE microwaves.
Apr 28, 2017 | GE JES1358 Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
F3 error code ge microwave
No, unfortunately the membrane keypad is not available as a separate part on this model.
You would have to order the control panel frame, which comes with a new keypad already installed.
The part number is WB07X10883 and you can get it for $86.82 here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Nov 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
126 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
