Question about Dell Dimension E520 PC Desktop
BLUE SCREEN CANT GET ONTO WINDOWS HAVE PUT REBOOT CD IN
  • 808 Answers
Confronting Blue Screen of Death popularly known as BSOD is one of the worst nightmares for any computer user. It can happen in all the Windows versions. Win 7 is no exception to it to BSOD. Luckily, there are ways to fix Win 7 Blue Screen of Death problem.
Usually with BSOD, one can not do any work on computer. Computer hangs, restarts or shut down on its own. There is always a great danger of losing unsaved work.
The situation demand urgent action on your part to continue safe and smooth computing.
I am sharing few tricks of the trade that will surely help you whenever you see tragic Blue Screen of Death in Win 7.
Posted on Sep 08, 2010
    Guru:
  • 868 Answers
Blue Screen? I gues your getting a blue screen when you turn the system on there should be an error on the BSOD Blue screen of death and it may depend on what the error is being the reason why your system is crashing into a blue screen
Check this link: http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
and yeah one thing you can try is upon powering the computer keep on tapping F1 until you get another type of blue screen which is the BIOS of your computer, if you get that screen then that will be good in the case that you can check if you Hard drive is detected in the Options Boot or boot sequence check if your Hard drive is detected there if not then you issue is probably an HDD failure, another thing you can do is check you cables inside the system if all are conencted properly and none are lose. pls take time to check the error codes for it will help you as well on getting to the casue of you concern ^_^
Posted on Jun 06, 2010
  • 4,281 Answers
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
I have 1 problem hp intel atom,whn switch on very very slow and blue screen blank,sum1 help me plssss!!!!
You need to run the Check Disk Utility but I think you have a netbook that does not have a CD Drive. Lesson learned the hard way.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Without a cd drive you might have to just do a System Recovery which means you will lose all your data.
Apr 25, 2012 | Computers & Internet
Reboot with bcod on startup will get though windows 2000 screen and the straight to a blue screen of death
If you still have the Operating System CD, you can boot from the CD and do a repair.
The screen looks like this:
Where it says to repair the selected Windows 200 installation press R - do that and hit enter.
May 20, 2011 | Computers & Internet
Acer travelmate 630 blue screen
If you mean the CD drive won't open to let you put the XP cd in then look for a small hole in the drive lid which lets a straightened paper clip gently slide in to release a catch and let the drive open.
Alternatively make a boot USB stick and copy the entire XP cd to it
Apr 20, 2010 | Acer Computers & Internet
COMPUTER HAS COME UP WITH BLUE SCREEN . LOTS
Your Windows installation has died, it's very common. Insert your Windows CD, and reinstall it. If it doesn't boot from the CD, then you need to take it to a repair shop, but it doesn't look good.
Oct 27, 2009 | Packard Bell Computers & Internet
Just when it starts to go to windows it will recycle also when I try to put a new os error message will come up and it will shut itself down?
Okay. What your describing is normally a memory problem. Try pulling a stick of ram out if you have more than one stick in the machine. If it still starts funny then try another stick. Also, the reboot is likely to be caused be a boot error (obviously) that Windows automatically restarts. If you hit the F8 key during restart like trying to get into safe mode, One of the startup choices is to Not Reboot on Error. Use that one and when it errors it will give you a Blue Screen that you can get a number from like 0x0000007b so you can look it up in google and try to find a fix for it. If you cant get out of the Reinstall of Windows and the install has not gotten too far you can do a windows system restore to get back to the correct startup. If you dont know how to do a system restore after you cant get to Windows heres some instructions on how to do a system restore with a XP CD:
http://icompute.info/System_restore_from_xp_cd.htm
If you have a Barts PE disk or an Ultimate Boot CD for Windows then the instructions for that are on that site as well.
Hope this helps...
Oct 19, 2009 | Computers & Internet
You'll need to setup the Acer laptop to boot from CD-ROM. Push either the F2 or F10 button when booting your laptop and it should bring-up the configuration management interface. Go through the options and confirm that Boot From CD-ROM is at the top of the list on bootable devices.
Next, you'll need your original Windows XP CD that came with the Laptop. Put it in the CD-ROM Drive and reboot your laptop. You will be given two options: 1) Re-install Windows or 2) Repair the existing Windows Installation. I recommend that you repair the existing Windows Installation as this will not destroy and data or device drivers that are install on the laptop.
Good Luck!
Dec 16, 2008 | Acer Aspire 5050-3242 Notebook
My computer will not reboot
this will either relate to a hard disk fault or a corrupt driver or registry file, if you cannot get into safe mode, or last known good configuration, you may have to run a windows repair using your XP cd
Sep 14, 2008 | Microsoft Windows Vista Ultimate Edition
ValuSoft's "Complete Bible Collection"
Have you tried to boot into Safe Mode? if you can do so successfully, you'll have a good chance of being able to undo some of the damage. Did you create a system restore point before the install?
Sep 28, 2006 | ValuSoft Bible Collection (10281) for PC
Dell Dimension E520 PC Desktop Logo
224 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
