Question about Acer Aspire One Netbook 8.9" Notebook
The battery was replaced with a 6 cell. After a few weeks, the battery will not charge. The laptop works fine with the battery removed.
  • 4 Answers
You will need to replace the battery with an orginal from the company itself to make it work correctly
Posted on Jun 06, 2010
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Tip
This is untrue. Charging a laptop while it is shut down is fine and it will in...
Charging of laptop while shut down may cause the corruption of operating system. While shut down battery level will store in the memory and in the shut down mode, if you are charging, it will store in another memory location. After that if you are switch on the system, it will compare both values. If both are not equal, it may be corrupt the operating system. I had affected by this. It wont happen in all times ..Once happened for me after that for knowing purpose i did the same for three more times.. But not the same result. Better to save laptop life, please dint charge while shut down
on Apr 25, 2011 | Computers & Internet
Tip
Laptop battery life tip
Extend your battery life on your laptop, do not leave it plugged in and charging all of the time. When a laptop is constantly charging, it will deplete the cells on the battery. Two ways to combat this, charge your laptop fully and remove the battery while it is plugged in, or you can run your laptop on battery power a few times a week until the battery dies.
on Dec 12, 2009 | Computers & Internet
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
My se C905 worked fine til today, I ended my call then it switched off by itself now it won't charge and it says you must use a sony ericsson battery, how can this be solved? Please help
Did u notice the battery was dying earlier then normal time since last few weeks/months?This can happen when the battery cells give up. Pls do not try to charge/overcharge this battery. Replace the battery and it will be back to normal.
Hope this helps.
Aug 11, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
MSI Wind u100 - battery LED flashing red
check for an update with windows 7 then go online to asus support or call them. They should have a solution for you.
May 12, 2010 | MSI Wind U100-053US 10-Inch Mini Laptop
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
I HAVE A DELL INSPIRATION 1525 AND AND BOUGHT A NEW 9 CELL BATTERY BECAUSE IT WAS NOT HOLDING CHARGE, EVEN WITH THE NEW BATTERY ITS DISCHARGING WHILE PLUG IN AND IN USE WHAT MUST I DO.
There are a few possible problems. First of all, check out whether it works fine with a different adapter. If it works, then replace the adapter. If the same problem persists with a different adapter too, then try this. Shut down the laptop and carefully remove the battery, check whether any dust particles there, clean it and put the battery back and try charging it. It should work fine. You have not mentioned whether your laptop lasts for more than 1 hr inspite of it saying the battery level is 40%, if it lasts then, there is no problem in your laptops battery.
Jul 30, 2009 | Computers & Internet
The battery doesn't stay charged in Guardian 10K
I think that is the problem as well. Temporarily, you could just buy a tricke charger from the parts house and hook that up until your other one is changed. Rick
Apr 11, 2009 | Guardian Electrical Supplies
Acer Aspire One Netbook 8.9" Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
