Question about Toshiba 55H70 55" Rear Projection Television
Where can i buy board for toshiba 50hx70 - Toshiba 55H70 55" Rear Projection Television
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can buy the parts for your Toshiba 50HX70 from this link. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
I have a Toshiba 50HX70... I fixed the convergence issue around 6 months ago. Now the sound does not work... I turn it all the way up and you barely hear anything... I did move it recently, did I know...
Best best would be to try the following:
Start with taking the back cover off of the tv.
1) Verify if you can hear any sound whatsoever out of the speakers. If so, that would indicate that the speakers are still connected to the circuit board. If not, then trace the wires from the speakers to where they plug on to the board.
2) if you hear sound (hiss) in the speakers, but not the audio signal from your program you are watching, then look to ensure all connecters are fully seated around the RCA jacks in the back.
If those two do no produce results, then could be a solder joint on the board finally failed after moving the tv, or the amplifier for the speakers has failed. If you hear sound though as in step 1 above, i would doubt it is the amplifier IC.
Feb 20, 2011 | Toshiba 50HX70 50" Rear Projection...
Remote and volume not working on toshiba 50hx70 after changing out convergance chips
Howdy,
It sounds like you may have not have plugged something in or one the connectors are not "seated" or securely properly/tightly.
Make sure there is not any cables and modules are properly (tightly) secured and tightly secured.
Good Luck, big IRISH.
Dec 28, 2009 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50hx70 sound but no picture
NORMALY SOUND BUT NO PICTURE IS THE LAMP YOU SHOULD CHECK THAT TO SEE IF ITS BLOWN
Mar 07, 2009 | Toshiba 50HX70 50" Rear Projection...
Toshiba convergence
There are kits available online, which include the chips and the soldering iron too.......Just a word of caution, convergence chip replaced is more difficult on Toshiba #1 the chips face other boards that must be remove first. the main one is the convergence generator (which the sheild is soldered in placed) Also the signal board (which is what everythings mounted to is very fragile)..............Good Luck
Jan 11, 2008 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 - red blinks but TV will not turn on...
Hi, you`ll need to call the tv guy then, you have a short in one of the power supplies, or possibly broken solder connections, either way the board has to come out and board repaired or parts changed, BMW Rider
Dec 02, 2007 | Toshiba 50HX70 50" Rear Projection...
No video, Blown fuse f470, audio works great.
check your h uot transistorthen check pico fuses
May 26, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 convergence problem
replace convergence ic,s part # stk392-110, you will need two of them.
May 12, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
