Question about Delphi Roady XT XM Radio Receiver
Changes channels, mutes itself,turns itself off, etc.
  • 3 Answers
Somewhere on the net sombody said they called tech support and was told to get a new 5V plug adapter (they are made by Belkin and available online). After suffering for a week with a loco XM radio, I got the new adapter and it worked like a charm!!! Its the thing that plugs into the wall.
Posted on Aug 21, 2010
Just bought an RCL3210 TV. The odd thing is that the Channel up/down key on the remote control does not change the channel. Also, the up/down channel key on the TV itself also does not respond. When you...
You need to find how to CLEAR the auto channel settings. Sounds like the TV is set to SKIP all channels. Look for a MENU and then look for an AUTO setting that will walk through all channels and set those where you have reception as the "list" that the remote and the Up/Down buttons on the tv will choose.
PS: GREAT writeup on your problem and the things you have tried.
May 08, 2017 | RCA Televison & Video
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
Can this remote work with the Western Digital HD player? How would you find this code?
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Jul 17, 2009 | Philips Magnavox MRU1400 Universal remote...
I need the codes for the sylvania television as i replaced the batteries and then it stopped working my tv
controlled.
SEARCH button.
Jul 16, 2009 | Philips PM3S Remote Control
MRU1400/17
controlled.
SEARCH button.
Nov 16, 2008 | Philips Magnavox MRU1400 Universal remote...
Remote codes for dish network remote?
1. Mmanually turn on the device (TV, DVD, etc.)
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quiclkly release the desired mode button 9TV, DVD, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device (TV, DVD, etc.) changes channel. The red indicator blinks once with each button press. If you accidentally overshoot the code required, use the CHANNEL DOWN button to backtrack through the library until the device again changes channel. Pressing the CHANNEL UP changes direction to forward again.
5. Press and release the MUTE button to install the code.
or try these
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917 good luck its one of these!
Oct 25, 2008 | Philips 20PF5120 20 in. EDTV-Ready LCD...
ZEN-SPA UNIVERSAL REMOTE CONTROL
Manually turn on the device( TV.,VCR,etc) to be controlled.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the code search button.
Press and quicly release the desired mode button(TV,VCR,etc).The red indicator blinks off once.
Press the CHaNNEL UP button repeteadly(up to 300 times) until the device to be controlled Changes Channel.The red indicator blinks off with each button press.If you overshoot the code required,press Channel Down button to backtrack through the library until the device changes channel.
May 29, 2008 | Zenith DBZN-311 Remote Control
Lost Instruction sheet for cl034
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
May 12, 2008 | Philips Magnavox Learning Universal Remote
Philips magnavox, universal remote
Hope this helps :)
Apr 23, 2008 | Philips Magnavox MRU1400 Universal remote...
Delphi Roady XT XM Radio Receiver Logo
176 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
