Question about Archos AV 500 Digital Media Player
I dropped the player and now the navigation buttons do not work and it takes a few attemps to boot it up the remote control fortunately does still work the player I have my whole music collection and videos of my children when they were young so i dont want to loose all this
  • 105 Answers
Connect your player to your computer and start transefering all your important files there, then find a local electronics repair shop near you and let them have a check on your player.
Posted on Jun 06, 2010
How to delete channels in roku
  • From the Roku home screen, select the "Channel Store" icon.
  • Use the up or down arrow button to navigate to the "My Channels" category (the top row), a list of channel you currently have installed.
  • Using the right and left buttons on your remote control, select the channel you wish to remove.
  • Select "remove channel."
  • Select "yes" on the confirmation dialog box to confirm that you wish to remove the channel.
Custom Wheels For Honda
Jun 14, 2012 | Roku HD Player (N1100)
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
Cannot advance thru the menu selections on exercise DVD with universal remote
To navigate in Menu to select desired part of file is needed original remote because universal remote does not have these special command. universal remotes have few common control buttons for routine control of any gadget.
Replacement remote for Samsung DVD-V2000 is available HERE and HERE as it will help you to select required scene in exercise dvd disc.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 03, 2010 | Samsung DVD-V2000 DVD Player/VCR
Unlock regional code on LG dvd player model DV480
I found the solution here.
http://www.videohelp.com/dvdhacks/lg-dv480/10008
Region code hack posted by vassmanov, March 23 2009:
Press the Pause button on your remote control. Using your remote control enter the code 3,1,4,1,5 and 9, At this point, a blue screen displays showing that you are in 'region altering mode'. Press the 0 button on your remote control for Region free. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player and your ready to go!
It worked for me (after a few false starts)
May 03, 2009 | Televison & Video
Push on button dvr says set 2
Press ENTER and number 2 together on the remote control for at least two seconds to restore control.
Feb 13, 2009 | Panasonic DMR-ES35VS
Denon DVD 2200 front control buttons don't work
I have had the same problem. After disassembling and refitting the buttonpanels and it's connectors the problem was solved. Does not seem like a repair but in my case it still works for about two years now
Jul 19, 2008 | Denon DVD-2200 DVD Player
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
How to Unlock Philips DVP5986K/98
Thanks for Solution. It works.. But how to check firmware version pages?
Feb 17, 2008 | Televison & Video
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
The input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Jul 11, 2007 | JVC AV-27F702 27" TV
Archos AV 500 Digital Media Player Logo
93 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
