Question about Samsung S850 Digital Camera
How to fix the card error on this camera. i replaced teh card and its says 'card locked'while its not locked.
  • 1,031 Answers
Check for the write proctect switch on the on the side of the card when its down the card will be locked ,slide it up to unlock the card.hope this helps pls do let me know
Posted on Jun 06, 2010
My camera Canon sd 940 shows an error memory card error and card lock, how to fix it?
Have you tried unlocking the card with the small slider switch on the side of the card
Feb 15, 2015 | Canon Cameras
Camera reads card error
Open the port that holds the card and remove the card see if its damaged or maybe that the lock that is located on the side of the card is in the locked position if it is set it to unlock and this should fix the problem if the card is damaged it needs to be replaced.
Nov 20, 2011 | Samsung SL102 Digital Camera
My camera says the memory card is locked so i am unable to delete pics or do anything
Step 1 : remove your card from the camra
Step 2 : on the edge of ur card u wull have a kind of switch. you just have to move it in teh opposite direction. if it is up pull it down and viceversa
Step 3 : put ur card back in camera and u can delet all teh pictures that u want to delet ;-)
Enjoy deleting.
Apr 28, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Memory card error card says locked
Hi!
SD cards (or MicroSD, using an adapter) are locked using a mechanical switch on their left side.
Simply, take the SD card (or the SD adapter) and change the switch position.
Usually the UP position is the Unlocked position...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
B
est regards,
Pelu.
Jan 04, 2011 | Canon PowerShot SD1100 IS Digital Camera
I have a canon powershot sx200 IS and I recently went on vacation and took a lot of pictures using teh SD memory card provided with the camera. For some reason, after almost filling the card I received a...
The likely reason this keeps happening is that these cards weren't formatted in the camera when you first got them. However, don't do so just yet as formatting also erases the card. If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones. Now AFTER you've recovered the photos, format the cards IN THE CAMERA USING THE CAMERAS FORMAT FEATURE. Look for it, it's located under the "tools" menu (look for the item stating the card's memory capacity). This should rejuvenate both cards, and prevent reoccurrence.
Aug 07, 2010 | Canon PowerShot SX 200 IS Digital Camera
Card error
the problem could be multiple things:
1. it's switched into card mode... without a cord 2. the card is locked, this can be fixed by retrieving the card from the camera, then pushing the lock switch down away from the word "lock" (the opposite direction of the tiny little arrow) 3. THe card is corrupted, for this there really is no fix, sorry.
hope this helped- snowsurfer58
Sep 19, 2008 | Canon ZR300 Mini DV Digital Camcorder
Camera wont transfer images to laptop
If the camera displays "Communication Error," when trying to download images the main cause for this error is that there are more than 1000 images stored on the memory card. It is recommended if there are more than 1000 images on the memory card, that you use a card reader to acquire the images, or to delete images off of the memory so that there are less than 1000 images to download from the memory card.
If this is not the case, there are not 1000 or more images on the memory card, try reconnecting the camera to abnother port on the computer, try another cable or another computer. This error can also display when connecting to a direct print printer. Please check with the printer manufacturer for more information on this error.
Sep 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera says card locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. That's it, should work now.
Sep 01, 2008 | Cameras
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
Samsung S850 Digital Camera Logo
145 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
