Question about LG Vu CU920 Cellular Phone
How to instal/use bluetooth on LG Cell Phone
How do I set up and use bluetooth on an LG Cell phone? What do I have to do to get started? Or where can I find an instruction manual on line?
  • 5 Answers
SOURCE: How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Posted on Nov 01, 2007
SOURCE: LG CU500 cell phone Call Divert Set problem
  • The issue is caused by the phonejack/memory chip assembly, located in the upper right rear of the phone has become unseated/loose and is causing your issues. I had the same problem and after I took the phone apart and put the assembly back in position, I eliminated the problem.
  • If you are not mechanically inclined and/or have access to small tools and an open area to work in, do not attempt!!!! There are numerous small parts including the side buttons and keypad and the above mentioned assembly that are exposed when you seperate the two sections that make up the back of the phone. If you attempt the repair be extremely careful to note the position of parts before you take it apart and make sure they go back in correctly. It is a bit time consuming but doable.
  • If you feel you can't do it yourself I'm sure that there are some online options for repair or perhaps a local repair shop that would do the repair. Good Luck
Posted on Jan 05, 2008
Bajanguru
  • 7752 Answers
SOURCE: LG Voyager VX10000 Cell phone
I would advise you not to try self repairs if you are not accustom doing that, take the phone to a mobile service center and have the phone fix there.
Posted on Sep 21, 2008
bigbam51
  • 18 Answers
SOURCE: what is the default code to pair a bluetooth with a lgcu920
The Default code for my Lg Vu is 0000 so i assume it shall be the same for yours.
Posted on Jan 28, 2009
yurid316
  • 283 Answers
SOURCE: Dont know the passcode to unlock the bluetooth on
in recieving or sending through bluetooth just press 1 to your phone when asking pass code and also press 1 to other who is reciever or sender.tnx
Posted on Aug 01, 2009
How do i set up bluetooth for my lg phone
go to your bluetooth settings
turn on your blue tooth
on the page you will be able to change your phone name
scan if theres any bluetooth device around
and you can save the pairing within the two devices.
Whenever you wanted to pair with another bluetooth device with your lg
scan first and when your phone detected the other device and then you can select that device and start the pairing
Once paired you can start the file transfer or any thing that your lg phone supported on bluetooth mode..
Hope this information has help you..have a good day..!!
Jan 31, 2012 | Cell Phones
How to transfer files from a cell phone to a desktop computer? Computer is Win XP SP3 Cell phone is LG 230 Connection is via USB2 port via Bluetooth Dongle Asus USB BT211 The Bluetooth...
you might need to install a mobile phone suite which is a program that will let you install a mobile phone to a computer this will have to be specific to your phone there are a number of phone suites nokia Samsung sony ericson to name a few here is a phone suite link hope this helps
http://global.mobileaction.com/product/product_USB.jsp#bottomContent
Apr 13, 2011 | Computers & Internet
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
How can use themes on lg kp220
Quick installation instructions:
* Download the LG theme and unzip it on your PC or Mac
* Transfer the theme files across to your LG phone using an USB cable or Bluetooth and you are done
* You can also set the image files as your preferred Main screen, start-up screen and shutdown screen
Downloads
Aug 08, 2010 | LG KP200 Cellular Phone
How can i get themes for lg gd510
Themes Downloads
May 12, 2010 | LG GD510 Cell Phone
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Oct 25, 2009 | LG RUMOR Cellular Phone
How do I use bluetooth wireless adaptor to transfer photos from my LG VX5300 cell phone into my computer.
connect your bluetooth adaptor to your computer and let the computer install the necessary drivers for it. when it is successfully installed, you will then be able to use the bluetooth adaptor to browse through a bluetooth network your LG phone when you set your phone's bluetooth visibility to ON
Oct 14, 2009 | LG VX5300 Cellular Phone
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Bluetooth connection to my LG Renoir KC910
Go into control panel, click on bluetooth icon. Tick box 'allow bluetooth devices to find this computor.
Switch on bluetooth on phone and search for new devices. Message on computor, a device is trying to connect. click on message enter code, 0000. enter same code on phone when prompted (be quick).
Start LG pc suite, connection wizard, click bluetooth then next, enter code 0000 when prompted.
Look at phone enter same code, 0000, when prompted and hey presto all will work.
Hope this helps
Regards
Max
May 01, 2009 | LG KC910 Renoir Cell Phone
Instructions
Hi Deborah!
First of all you need to activate the bluetooth on your phone, after that turn on your headset, now get in the bluetooth menu on your phone, select search for bluetooth items, your phone will find your headset and it will ask you if you want to connect to it, select yes.
Many headset have a code, that code is neede to connect to the phone. if your headset have one the code should be in the manual that came with the headset. If your headset dosent have or need a code it will connect to your phone as soon as the settings is done on the phone.
Good luck
Nic
Feb 28, 2009 | AT&T LG CU515 Cell Phone - Black
LG Vu CU920 Cellular Phone Logo
189 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
