Question about Dell E176FP 17" LCD Monitor
Lcd monitor blinking bad resolution - Dell E176FP 17" LCD Monitor
    Scholar:
  • 156 Answers
Try updating the drivers for the video card, and check it on another system,if both doesnot work, you know it is a bad LCD
Posted on Jun 06, 2010
My Acer TCO03- power button is just blinking but no picture display
Blow hot air into the back with a hair dryer before trying to start it.
(not kidding)
if that works, one of the capacitors on the power board went bad.
even if that does NOT work, one of the capacitors on the power board went bad.
It is ALWAYS one of the capacitors on the power supply gone bad.
Being unplugged for a few weeks - as you stated - drained it of "juice", and it just cr*pped out. It was going to fail soon, in any event.
Fixing it can cost you less than a dollar, if you Google for information.
Best of luck!
Mar 03, 2015 | Acer Monitor Lcd 19in Al1923 0.29mm...
When monitor blinks a analog box pops up and the box says somthing like 1920x1200 60 hz. what does this mean?
It is telling you that it wants you to set your PC video resolution to the monitor native resolution of 1920x1200 @60 hz.
You may be able to turn off the resolution notification in the on screen setup menu.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Aug 12, 2011 | ViewSonic VX924 19" LCD Monitor
Whener i connect it i get a blinking box with message "non optimum mode- reqired 1280X1024" the service centre guys says the board is damaged (of the monitor) and requires replacement what to do??
That is the recommended native resolution for this monitor, do you have your PC video resolution setting to this number? If you do and it stills get this pop up then you may have problem in the logic board, I would also check the DC voltage to make sure it has clean DC feeding the logic board, it may be due to bad caps.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Aug 30, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
Gateway FPD 1975W LCD monitor,on light blinking, but wont turn on
I will assume you have already try this monitor with other PC? You should also set the PC VIDEO output resolution to be at native resolution of this monitor, which is 1440x900 @60Hz.
Mar 29, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor blinks at random intervals at 1024x768 resolution but never at 800x600.
Your Video Card doen't support the 1024X768 that is why your first resolution is blinking and your second resolution is staying on.
Dec 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Fpd1975w display flashes on and off
what resolution are you setting your screen to? if you are setting it too high or to a resolution/frequency that your monitor doesn't support, it will do this. Try setting it to 800 x 600 w/ 32 bit color and a frequency of 60Hz. If you do this and the monitor still blinks, you may just have a bad DVI cable.
Jul 13, 2009 | Gateway FPD1975W 19" LCD Monitor
Resolution of the text
What is the resolution that you are running the monitor at? There are two possible reasons that come to my mind.
1. You are running at a non native resolution. Based on your LCD spec you should run it at 1280x1024 resolution to have very sharp text as you normally expect from LCD's. However if you have set another resolution (say 1024x768) the text is blurred and this is a known issue with LCD's, which unlike a normal CRT monitor will get blurred running at any other resolution :(
2. You have not installed the monitor driver, hence again this limits your resolution and windows only allows you to select a resolution that is non-native (Meaning since the driver file is not there the operating system may not allow selecting the native resolution the monitor should run at). You can find the driver file at the samsung site. Its a common driver file for all LCDs.
Dec 12, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Blinking L.E.D. light on dell monitor
Try lowering the screen resolution to 1024x768 and see if it displays on the screen. You will need another monitor (possibly CRT as they do high resolutions) to do this.
Nov 09, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Dell E176FP 17" LCD Monitor Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
