Question about Miele Washing Machines
Miele W307: Wet clothing
Miele W307: It seems to be working normally, pump is running, but clothing are wet. Start centrifugation manually works fine. Does not happen every time.
How to use Miele w 307
Posted on Feb 08, 2015
  • 641 Answers
SOURCE: Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Posted on Jul 19, 2007
  • 250 Answers
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 09, 2009
  • 107 Answers
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Posted on Mar 13, 2009
proJekttaLon
  • 91 Answers
SOURCE: after the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
Posted on May 25, 2009
beltronic205
  • 1466 Answers
SOURCE: ATF6000FS1 Frigidare front load washer The
Suggests that motor not not tuning heavy loads due to worn belt or motor.. you could check if Carbon Brushes are worn if they are fitted some motors dont use them..good luck
Posted on Nov 16, 2009
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
How to use Miele w307
its a washing machine so
all you have to do is
place washing {dirty clothes} into it
close the door tight
then add some soap {about a cup of powder}
you turn the machine on
select the proper program
and hit start
then some mins later you return
and decant the now cleaned clothes
its quite easy
Feb 08, 2015 | Miele Washing Machines
New washer- WTW5000DW0 / C43742143 clothes not spinning
are the clothes very very wet ? is the machine emptying properly? you could check that the pump isn't blocked or partially jambed I'd start at the pump first, barring that it could be the main program controler
Nov 30, 2014 | Washing Machines
Not heating
If you can hear the dryer start and operate but at end of cycle your clothes are wet then it is likely (assuming the heater is turning on) that the fluff collection on the condensor unit is blocking its operation.
Refer manual at this site and follow instructions on page 20.
http://www.eirvik.is/gogn/L/t233c.pdf
Apr 19, 2014 | Miele Novotronic T230C Electric Dryer
Rinsing and centrifug error
This unit needs a a drain pump
Jan 20, 2014 | Siemens Washing Machines
Clothes seem too wet after final spin
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 01, 2009 | Kenmore Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer not working properly
its likely to be the condenser unit in the rear of the machine full with lint check for a large clear / opaque unit with pipes connected and make sure it is clear
Jun 19, 2008 | Equator EZ 3612 CEE Front Load...
Washing Machines Logo
231 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
