Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
About holding the connect button on router...
I first set-up my linksys wireless adapter on my cpu & it workedfine (plug & play) & got connection whenever I insert it.
Now, sometimes my wireless usb adapter loses its connection to therouter, then as a solution: I tried holding the button on routerlocated on its surface(the center button), I've done it once or twice& it worked, but now there is no connection....; the window promptsays I should hold that button for awhile and look for a LIGHT &press connect within 2 minutes(?!).
I want to ask: what LIGHT should I look out for? The prompt didn'tspecify which----is it on the wireless usb adapter or is it on therouter itself? And, when should I press the connect button on thescreen: after the LIGHT is on after the 2 minutes?
  • 76 Answers
Reset router
Posted on Jun 06, 2010
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
How to set up router with a lap top
well you will have to setup the router to run on ethernet, perform a mac clone for your cable modem then setup the wireless.
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I fogot my password for my Linksys router. How do I retrive it?
There should be a reset button on the back of the router, hold it in with a pen or something thin and hold the button for 10 seconds and release to reset the router, the password with default back to the factory setting.
Apr 02, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
Cant rember password
Your wireless router is prompting you for a password in order to log onto your network. If you do not remember your password, you can reset the routers' configuration by holding down the reset button on the back of the router, and you can then use the default user name and password to change the settings. HOWEVER, you will lose all of your network settings so if you have multiple devices connected via wireless,they will also have to be reset.
If you need help re-configuring your router, visit the router manufacturer's web page. There should be a tutorial to walk you through the process.
If you happen to have a Linksys wireless router, here is their page: http://www.wikihow.com/Reset-a-Linksys-Router
Sep 06, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
How do i set up the wireless to cable internet
Plug in the power adapter. Connect an ethernet cable from the modem to the input on the router. Wait 2 minutes. Test it. If it doesn't work yet, press and hold the reset button for 10 seconds, wait another minute, and try it again.
Jul 06, 2009 | Linksys Wireless-G WRT54G Router
Can't connect my gaming adapter to my wireless network
If the ethernet light -( )- is off, flip the X - II switch to its other setting.
If the wireless light is off, click on the channel button, it should me IN. If still cannot connect, then you will need to setup the wireless settings of the gaming adapter.
First, you need to know the wireless settings on your wireless router or access point. Take note of the wireless network name (SSID) and wireless security settings.
Connect the gaming adapter to the router using an ethernet cable. Flip the switch on the adapter to straight through (II).
Then insert the Setup CD of the WGA11B to your computer. Click on the Setup button once the wizard is up. It will then show you the current settings, so just click next.
It will ask you for the password of the adapter, just type admin.
Make sure that Obtain IP address automatically is selected, then click next.
On the Profile configuration, select Internet for the mode.
Then enter the SSID and select WEP if wireless security is enabled on the wireless router. Type the passphrase of the WEP key. Then click No to complete the configuration.
Connect the gaming adapter back to the PS2.
Apr 09, 2009 | Linksys Wireless-B Game Adapter 802.11b...
Linksys wireless access
There should be a recessed reset button on your router. Using a paper clip or something small press and hold the reset button. While holding the button, unplug the power adapter and continue holding the button for ten seconds plug the power adapter back in, and continue holding for another ten seconds just to be through. This should do a hard reset and your router will return to the default. For the default you have no username and your password is admin.
May 14, 2008 | Linksys Wireless-G WRT54G Router
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
222 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
