Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Why wont my poulan riding mower start with the key and new battery keeps going dead
  • 36 Answers
Clean all the connections from battery to starter, selonoid connections to and ground cable where it connects to the battery and to where it connects to the frame it might just be a bad connection on frame i seen alot of poulans with this problem.
Posted on Jun 07, 2010
Poulan riding mower wont crank. wont turn over. no head lights
bad fuse more than likly a bad ignition switch
Sep 14, 2014 | Poulan Garden
Why poulan pro riding mower wont charge
First check your battery, make sure the cells are good and no bad cells. If that is good then the issue is under the flywheel. There is a coil under your flywheel that serves as a generator. You can just purchase a 2 am charger with a breaker, that will kick out when battery is charged and hook that up after each use. If you jump a unit or charge a unit with more than 2 amps, you can burn the generator coil out under the flywheel. Also check the magnet under the flywheel. I have seen them come out.
Aug 24, 2014 | Poulan Garden
I have a simplicity 1691931 riding mower with a new battery.it wont start.
check the wiring again possible bad -corroded positive line to solenoid or have a bad key switch -check the inline fuse to the solenoid
May 23, 2013 | Garden
I have a poulan riding mower and when i go to start it it only turns over a couple times then it wont move anymore
sounds like the battery is weak try and jump start it with your car if that doesn't help try and jump it at the block and solenoid the battery cables could be bad
Apr 09, 2012 | Poulan Garden
Poulan 38" riding mower.
Battery is likely dead - or has built a sediment bridge - shorting the anode and cathode.
Jump-start the tractor with your vehicle - or another battery to check.
Or - use a multimeter to ensure your battery is not draining to 0V when you attempt to start.
This also indicates a failed battery. It may have a decent float charge - but when the load starter) is applied - the voltage will drop right out.
Thanks for using FixYa!!
Aug 03, 2011 | Garden
My battery keeps going dead on my poulan pro 500ex rider i already replaced the battery 4 months ago and its dead again.
Not too surprising. Unless you use it very often, the battery will go flat fairly easily. Was the old battery tested to have failed? It is possible you have a bad alternator or connection to the alternator. An easy way to keep your battery is with a float charger; it keeps the battery charged to perfection and ready to go. I have no power to my shed, so I use a solar one. It cost about 34 dollars at Harbor Freight (.com) Farmerbear at FixYa.com
Sep 28, 2010 | Poulan Garden
Cranks sounds like a dead battery but battery is charged wont start and will start if jumped by a truck battery
You may have a dead cell in the battery. Have you had a load test done on it. I use 300 CCA batteries and recommend them on all riding mower. They may cost a little more but well worth the cost.
Feb 25, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
May 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
380 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
