Question about Hoover Nextra HNF 3167 Top Load Washer
Good Day I have a Hoover Top Loader Giant loader plus 10.1kg washing Machine. Everything works but it wont fill water from the Tap ! I have to do it manually with a hose. Regards Dion
Hi there you may have a faulty inlet solenoid, this may not be the case if neither hot or cold works. Hope this helps Wayne
Posted on Nov 06, 2010
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hoover 705 , overfills and fllods laundry can it be fixed
On my hoover 200m (top loader) I had a similar problem. I turned off the machine & unplugged it. Closed water taps both hot & cold. Manually emptied machine with large cup. Undid bottom outlet hose by unclipping.The residual water will come out! I undid the 3 screws on the control panel. Tilted the control panel forward. The water level is manual control using a diagaphram pressure control to set water level. This had a hose. I disconnected both ends and used a bicycle pump to blow air thorough it. Underneath I disconnected where the hose goes into machine (clips) and also blew air from the top to check it was clear. After reconnecting everything the machine now does not stop filling and does not overflow anymore. Hope this helps.
Jul 28, 2012 | Hoover HTC243 Top Load Washer
The cold water inlet is slow to fill machine but the hot water inlet works fine
Hi just read your posting.Could you please supply the model of your hoover and tell me if it is a front or top loader.The fault on your machine is due to a faulty cold water valve or dirty inlet filter.Turn the cold tap off and remove the cold water hose from the tap end and check to see if the little filter at the end of the hose is blocked.If it is, clean it and put back the hose to the tap and try a wash cycle.Please reply with additional information and to tell me how you got on with the filter.
Jun 29, 2010 | Washing Machines
Top loader 600MB fills water but wont wash or spin.Water fills to right level and timer turns o.k.
Check the lid switch for proper operation. If the switch is bad or not being actuated by the lowered lid, it will block operation of the machine.
Oct 20, 2009 | Hoover HTC243 Top Load Washer
The service light remains on and the washing will not start.
Hi, make sure there's water in tap that feed machine, if there's, lock off you water, remove hose where it's connected to machine. valve on machine where you remove hoses from, check inside you will see strainer, clean any debris that's there, could be blockage of water entering machine, washer will start only when there's water in it. if it were clog up and you clean it, then connect hoses back to machine, and try it. if that didn't work, then you will need to check, water solenoid valve, that's the same valve, your two water hoses connected to, sometimes they burnt out, especially when there's low water pressure in tap, you didn't say what type of washer you got, top loader or front loader, if you got a top loader, fill it manually(bucket) and it will start, if water solenoid valve burnt out, if you got a front loader, you won't be able to fill it manually, if these tips didn't work, you will have to call mechanic, to make other checks. good luck
Aug 07, 2009 | Washing Machines
Washing machine cold water not filling
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Sep 10, 2008 | Washing Machines
Hoover Nextra HNF 3167 Top Load Washer Logo
230 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
