Question about Sea and Sea MOTORMARINE II-EX 35mm Point and Shoot Camera
Disassembly of Sea and Sea Motormarine II camera
Where can I find the disassembly instructions for the Sea and Sea Motormarine II underwater camera. The internal battery connectors have corroded and I need to replace them but cannot see how to remove the internal set from the camera housing
    New Friend:
  • 3 Answers
I have A Brand New still in the BOX MOTOR-Marine II contact me @ laradon611@yahoo.com. This should fix your issue.
Posted on Feb 26, 2013
3 Suggested Answers
  • 12 Answers
SOURCE: I don't have the motormarine II camera's manual.
Here it is at the Sea&Sea website
Posted on Apr 13, 2009
SOURCE: Sea & Sea MOTORMARINE II-EX 35mm Film Camera
Check this manual:http://www.seaandsea.com/PDF_manuals/MOTORMARINEIIEX.pdf First read page 42 to make sure you have correctly wound the film up to avoid accidentally exposing over your pictures. Then check page 32 for instructions on removing the back panel.
Posted on Mar 14, 2011
Drivers for the dx 8000g
If you mean the drivers to connect the camera to your computer, you should look for the CD that came with the camera. If you don't have the CD anymore, you could try the website from Sea and Sea, because there you also can download software. Perhaps they ask you to register the camera first, but having a serial number is the most they will ask.
view the link and look under support quick links.
Sea Sea USA Underwater Photography Cameras Video
Jan 10, 2014 | Sea and Sea DX-8000G Digital Camera
Sea & Sea MOTORMARINE II-EX 35mm Film Camera instruction how do i get the film out
Feb 13, 2011 | Sea and Sea MOTORMARINE II-EX 35mm Point...
Question on SnapSights waterproof camera
The SnapSights SS03 is a non waterproof camera supplied with 200 ISO film so you clearly have the SS01 model for 800 ISO. Both cameras have fixed aperture and shutter speed and rely on the wide exposure latitude of print film. 100 ISO is ideal if you have a camera with a wider aperture than yours, but if you use it then photos will be three stops underexposed; you'd possibly get away with this on land but underwater shots typically have more shadows than highlights and you'd lose a lot of photographic detail. By using 800 ISO the camera will produce photos which are noticeably grainy and with high contrast demonstrated by less detail in shadow areas and overexposed highlights, but for most purposes the photos will be acceptable and far better than none at all.
Colour negative film has a wide exposure latitude so you may wish to experiment with using 400 ISO or even 200 ISO. 400 will be one stop underexposed, but the printing stage can compensate to produce shots which are less grainy with better shadow details but which will lack some highlight detail. This can be partially compensated for if you tell the processing lab to "push process" your film at 800 ISO, but this will usually cost extra and for just one stop under I wouldn't bother, 200 ISO is really stretching it though and you may find that results are unacceptable unless you push process. Ultimately, it all depends upon how dark and how deep you go, but at much below 1,5m everything gets a strong blue colour cast anyway unless you use a powerful underwater strobe light mounted away from the lens axis.
Basically your camera is designed just to give you a taste of underwater photography and is very limited in what it can achieve. Even with a good specialist 35mm underwater camera such as the Sea & Sea MotorMarine II I usually find that I only have one or two usable shots on a 36 exposure roll, so if you do get the underwater photography bug then invest in a decent quality underwater digital model which accepts a proper external strobe lamp. The ratio of failed photos is similar, but at least you can review and delete them immediately without expense.
Jan 09, 2010 | SnapSights Intova Snap Sights SS03 Film...
What are the steps to replace engine coupler in a mercruiser 165hp
First put the boat in forward, then undo the 6 nuts that hold the outdrive to the transom, then undo the 2 nuts that hold the end of the lift cylenders to the outdrive, tie the rods up out of the way. Wiggle and pull the outdrive free, the coupler will be hanging from it. It is worth checking the support bearing in the gimbol housing as well as the u?js in the coupler.
Aug 16, 2009 | Sea and Sea MOTORMARINE II-EX 35mm Point...
Key noise how to silence on v3xx
go to menu,,,settings,,,sound settings,,,kepad tone.
Jun 17, 2009 | Sea and Sea MOTORMARINE II-EX 35mm Point...
Sidekick 2 keypad
Try this site http://www.instructables.com/id/Sidekick-II-disassembly/ It will show you how to tka e apart.
You will have to figure out from there.
Jan 18, 2008 | T-Mobile Sidekick II
Sea and Sea MOTORMARINE II-EX 35mm Point and Shoot Camera Logo
127 people viewed this question
Top Sea and Sea Cameras Experts
Are you a Sea and Sea Camera Expert? Answer questions, earn points and help others
