Question about Rti Technologies Rti T1 Remote Control
I have a RTI T2C controller not working
I have a RTI T2C controller about 4years old contolling a Crstron system of 3 audio visual areas & controlled lighting throughout the home.The dog jumped on the couch, hit the remote & changed channels & brought up info on the plasma. Later that night the remote didnot work, no screen or button functions. The blue charge light comes on when put in the charger but thats all. I have not had a new battery in the remote since new. Appreciate any assistance.
RTI Install
SOURCE: New RTI remote went black. Fully charged but nonresponsive.
Whenever possible contact an authorized RTI dealer in your area for support help!
There are a couple of reasons that a T1 or T2+ goes black. I understand that the screen does not light but if the buttons do not light either. The first most obvious reason is the battery is dead, even though it may act like it is charging. Pop the back off and check to see if the battery is slightly bulged. If so, it is for sure finished with its life. Further if the battery is over 2 - 3 years old it is probably done. Replacement batteries are available, but changing them requires more knowledge than just knowing how to use a Philips screw driver. The mother board battery connector is very susceptible to damage, so you must take great caution to hold the white mother board connector down gently on the edge with a small screw driver while you pull the white battery connector out.
Another potential problem area that will cause the screen to go off or become fractal is that there is an internal screw in the lower left that clamps the keyboard circuit board in place. This is also the ground clamp for the keypad illuminating surface. If this screw was not installed tightly the contact surface underneath will burn off. I have successfully repaired several of these by placing a triple folded small piece of aluminum foil in place of the burned out contact material under the screw and clear plastic illuminating sheet then tighten up the screw.
Only perform repairs if you are qualified to do so J
David
Master A/V Systems Integrator
www.soundandtheater.com/home.htm
Posted on Mar 08, 2010
SOURCE: rti remote doesn't work properly
Call a company that sells RTI products and they can reprogram it to work your new system. www.affordableavsolutions.com
Posted on Apr 12, 2010
  • 9 Answers
SOURCE: how do i change the battery for the RTI universal
The remote keeps it's memory in a non-volatile memory chip which is unaffected by power loss. So changing the battery is safe. The replacement batteries can be ordered from your RTI dealer for $45. Be careful with a T1 battery connector, they are delicate and can pull away from the board leading to an expensive repair. I'd suggest taking the remote to your dealer and have them replace it for you.
Posted on May 11, 2010
  • 9 Answers
SOURCE: I dropped my RTI T3 remote and now the touch
T3s and T2-Cs are very delicate and often go to the White Screen of Death WSoD when dropped. (a play on the term BSoD from windows)
The remote needs to be serviced to fix this. If you explain the remote goes to white screen when you call RTI they will understand.
their tech support number to get a return authorization is here. They will explain how to pack and ship it.
(952) 253-3136
gopakumarg43
  • 74383 Answers
SOURCE: My RTI T1-B remote suddenly
Hello
It will be an internal contact problem. To rectify it you have to open your remote control and clean it well with. there may a seating screw in some type of RTI remotes, can be seen inside its battery compartment. Unscrew it out and just slide out the top and botton cover portion of you remote contro with some sharp instrument, and can be slide it apart. Be carefull without breaking it. there are four inside locks at its side lenghtwise, should be located and press that portion insde to get it apart. Inside you can see an IC with three of four components, Since your remote does works for all other functions except volume and channel, the possibility is there is some trouble in thae track or contact. Clean it well with a cotton cloth dipped in rectified sprit or medical quality turpentine. Rub well to release any dirt or dust on the print side of the pirinted board inside, to which the rubber touch pad comes in contact with. [NEVER use petrol or such hard solvents] as thay harm the rubber parts and plastic parts. Reset the remote control, and reprogramme it according to its manual as you did before. Till it finds to be non functional, with respect to voluem and channel selection, it may be ither Ic trouble or track trouble. Both are irrepairable in case of any remote controls. OK.
Posted on Mar 19, 2011
Remote in not charging; just blinking
If the remote is over 4 years old it's most likely the battery. Just need a replacement.
Jun 08, 2014 | Rti Technologies Rti T1 Remote Control
Rti T3 eats battery's every 3 month's
Check for a stuck key that is draining the batteries.
Nov 06, 2013 | Rti Technologies Rti T1 Remote Control
My 1 year old RTI T2+ suddenly will not charge. I've tried charging it on 2 separate charging stations with no luck!
Try replacing the battery. If this does not fix the problem the charging circuit may be bad and need service. Go through your dealer if you purchased it that way and they may be able to provide you with a loaner while it's sent off to service. Or call RTI yourself and setup a service request. (952) 253-3136
Feb 06, 2010 | Rti Technologies Rti T1 Remote Control
David
Sep 27, 2009 | Rti Technologies Rti T1 Remote Control
Rti remote doesn't work properly
The best advice I can give you is to contact Total Control Remotes (www.totalcontrolremotes.com) or info@totalcontrolremotes.com. They are an authorized RTI dealer and specialize in programming RTI remotes and all related equipment. Not only is the customer service excellent, but the pricing is great. They will get you back on your feet in no time. You should not let a control system of this type go wasted.
Jul 31, 2009 | Rti Technologies Rti T1 Remote Control
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Rti Technologies Rti T1 Remote Control Logo
1,334 people viewed this question
Top Rti Technologies Televison & Video Experts
Tom Chichester
 Grubhead
Grubhead
Are you a Rti Technologies Televison and Video Expert? Answer questions, earn points and help others
