Question about Panasonic Lands Phones
I just purchase a panasonic KX-TG8220BX. No matter what I do i cannot register the phone to the base...nothing happens....please help. I follow all the instructions on programming the phone to the base and nothing works. The phone keeps telling me to place the phone on the base and press a certain button for five seconds. but nothing happens..it says please wait....and it just eventually goes back to the home screen.
My phone is not working well now ther are light flashing and the unit not responding .
if i try to dile after sacend it will shut off
Posted on Oct 18, 2010
How to register Panasonic KX-TGA-405 Range Extender with existing Panasonic Base Model KX-TGF570
According to the manual for the KX-TGA405, you need to do the following steps to register the range extender to any compatible base (including the KX-TGF570). First, unplug the range extender's AC adapter. Press and hold the Locator button on the base (KX-TGF570) for 5 seconds or until the registration tone sounds. Within 90 seconds, plug in the KX-TGA405 AC adapter. After the status indicator light on the range extender becomes green, press the Locator button on the base to stop the registration tone. Depending on where you place your range extender, you may need two people with two-way radios to complete these steps in the 90 second time limit.
See page 4 of the KX-TGA405 manual for the Deregistration/Registration steps. Panasonic has the manual here: ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga405_en_om.pdf .
I hope this helps.
Aug 22, 2017 | Panasonic Lands Phones
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Mar 24, 2017 | Panasonic KX-TG2356 Cordless Phone
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
Expandable handset will not register
It sounds like the base unit has other handsets registered to it. This is why you are getting the message "All Handsets Registered". You will need to reset the base unit in order to register your two handsets.
Hopefully this will help you. Put the phone in an easily accessible spot where you can plug it in and unplug it easily. Unplug the phone, wait a few seconds, and plug it in again. Now, unplug it again, and before you plug it in once more, hold down the Locator button as you plug it in and all lights should flash on. It should emit a long beep, which means it has reset. If not, you will need to unplug it once more and hold down the Locator button again as you plug it in.
Once it beeps, it should allow you to add your handsets. If there is nothing on the handset display, press the off button, menu, then 001. It should then read "Press LOCATOR on base for 3 sec, Then press ok". At this point, you will need to hold down the Locator button until it flashes before hitting okay. The handset will be registered when it reads "Handset 1 Registered".
If this doesn't work, I would call Panasonic.
Good Luck!
~Julia
Jun 04, 2009 | Panasonic KX-TG6071M Cordless Phone
Register hend set to base
Try the procedure on page 62 of the following PDF, and post your results.
http://www.conversationpiece.ie/download/KXTCD505.pdf
Mar 23, 2009 | Panasonic KX TCD650E Cordless Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
Lands Phones Logo
134 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
