Question about EliteGroup nForce3-A Motherboard
Motherboard battery backup is failing, how can I
ESC Nforce3-A motherboard battery backup is failing, how can I repair this?
  • 11,800 Answers
It's the big silver round battery on the motherboard, just replace it.
Posted on Jun 06, 2010
When I turn my compaq CQ56 on it says press esc for startup menu then I when I hit the esc button it just makes a humming noise
The motherboard of your laptop can't detect the Windows boot loader: either the Hard disk died and it no longer communicates with the BIOS or the motherboard itself has failed. To find out which press F10 while the laptop starts to enter the BIOS and see in there is the disk is still recognized.
You can replace the disk and then reinstall everything or , if that fails, the entire motherboard will have to be replaced. The replacement procedure of the board is very complicated, only a repair shop will be able to do it.
Jul 02, 2011 | Computers & Internet
I cannot get a sata 500gb hard drive to work on my nforce3 - a939 board
Verify that SATA is enabled in the motherboard bios. If the drive is new, you will need to go into disk management and set it up for use.
Jan 03, 2010 | EliteGroup nForce3-A Motherboard
Motherboard seems to have failed
I suggest you take a look on newegg.com catalog, it provides a lot of information on the products such as, but not limited to, size of the motherboard and full specs of it.
You need a Motherboard which is in the Micro ATX size range
(which goes from about 17x17cm to about 24.5x24.5cm) check Micro ATX models to find one that fits your needs.
you can buy the motherboard directly from newegg or fid the model you like and buy it somewhere else.
Feb 19, 2009 | ASUS Computers & Internet
Elitegroup nForce3-A Motherboard
check the power cord of your monitor. If problem persist give it a nice kick and you should be OK.
Jan 20, 2009 | EliteGroup nForce3-A Motherboard
CPU Fan connector
Hi vinbren,
There is probably an option in your system setup (BIOS) that will disable the CMOS from detecting a dead fan. While you may be putting yourself in harm's way should the fan actually die and the shutoff mechanism is thereby disabled, it sounds like since you're using an auxiliary connector this wouldn't apply to you anyway.
Check the BIOS setup (generally accessed by pressing F1, F2, F10, del, or ESC when the system first POSTs) for hardware monitoring and see if you can turn it off.
Ben
Mar 04, 2008 | AMD Asus K8N-E-DELUXE nForce3 Mainboard...
I replaced motherboard and can't boot-up
When you say posts, I assume it can get to the BIOS setup screen. Does it recognize any of the HD's? Your ATA controller or SATA controller may not be enabled. I wonder if the Windows installer detects a major hardware change and refuses to work under their obsurd anti-piracy policy.
Feb 12, 2008 | EliteGroup nForce3-A Motherboard
ECS Nforce3 A Powers down
Doubt its the bios. Did you install the sata drivers during boot? When u say it powers down does it just switch off or blue screen first?
Jan 05, 2008 | EliteGroup nForce3-A Motherboard
I lost my manual on hooking up the wiring on my nforce3-a motherboard.
Chances are, you can download the manual from the website of the manufacturer. That's probably the smart move. Last thing you want to do is try and do connections without it. That's a quick way to go through more than one.
JD
Digital Advisor
Dec 01, 2007 | EliteGroup nForce3-A Motherboard
Nforse3-A ver 1.0a 400DDR motherboard
Just click on this link, then you will get a picture of the jumper setup for the power switch, reset switch & the hard drive & power leds where it says SW1.
<a href="http://s182.photobucket.com/albums/x23/partywithjim/?action=view&current=NFORCE3-A.jpg" target="_blank"><img src="http://i182.photobucket.com/albums/x23/partywithjim/NFORCE3-A.jpg" border="0" alt="NFORCE3-A_motherboard_layout"></a>
Nov 17, 2007 | EliteGroup nForce3-A Motherboard
EliteGroup nForce3-A Motherboard Logo
96 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
