Question about Panasonic NV-DS37 Camcorder
Problems first started with condensation signal, after leaving it for several hours. Start in camera mode all ok, then I put tape in & press mode button for VCR. VCR light comes on for a couple of seconds then the camera red light starts flashing, the sign "press reset button" appears, which I did the camera turns off & then back on but the camera red light is flashing & the sign "to service" appears. When I start up with out a tape the screen shows what the camera is pointed at, but there is a small flashing red oblong box with a line going top left corner to bottom right corner and red dots in the back ground. Alan Head.
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony DVR TRV22
Error code shows problem in Take-Up Reel signal, its mechanical problem and can be repaired by qualified service technician.
Posted on Aug 04, 2008
SOURCE: Please reoperate after pressing reset button
When you switch it on the red led will light up but within 10 seconds it will flash and then a message on the screen will come on to tell you to reset then tell you "in service".
This will repeat itself forever to frustrate you no end but I have stumbled onto tricking it into working, ie get the led on without progressing to flash. Try switching it on and as soon the led comes on, switch it off, do this a few times, then leave the switch on and voila it might stay on like it did for me.
Just now I have ran it for an hour, switch it off then after 30 seconds turn it back on and it stays on.
I thick the reset button is all bull. Let me know how it all went or am I all bull for your NV-DS38.
Posted on Jun 20, 2009
SOURCE: Camera won't record / film
There is something wrong with your recording heads. TAKE IT BACK.!
Posted on Aug 18, 2009
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
Jvc gr d240 with a cleaning tape, the camera
its probibly early signs of condensation or a little damp air with faults of this nature same as lense cap fault and or condensation fault leave camera plugged in and switched on for a week . when camera has been on for a while dont put it straight into a bag or case leave it a room temp for a couple of hours after use before putting it away .
Jan 20, 2011 | JVC GR-D240 Mini DV Digital Camcorder
Safeguard mode 03 how can i remove cassette
Jan 16, 2011 | JVC GR-D250 Mini DV Digital Camcorder
My PD170 Start/Stop button cannot work (all 3 buttons). There's also no explanation on LCD. I already try to leave it for some hours with cassete compartment opened (hopefully it's only moisture problem)...
Sony cameras have a Hard-Lock switch that prevents buttons being pressed if locked, also make certain the tab on back of tape has not been slid to protect mode.
Jun 13, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Dew Detected message
When the camera's circuits detect condensation on the tape heads, this message is shown and the camera shuts down. This is to prevent damage to tapes, that could stick to the damp head.  It is recommended to leave the camera in a warm and dry place until sufficient time has elapsed for the condensation to evaporate. This may be several hours. Do not leave the camera anywhere too warm that is likely to damage it, like on a stove or radiator.  This issue is commonly caused by moving the camera from the cold outdoors, into the warmth of indoors. If the symptoms persist, the head may be dirty. try a head cleaner cassette, or failing that, return for service.
Dec 11, 2008 | Quasar VM-L459 Camcorder
Sony DVC-TVR20 won't accept tapes
most of the errors get solved with a hard reset
did you try it?
leave the unit plugged off from power for few hours
Jul 17, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
E04 unit in safeguard mode
I tried every method I could find from people posting on the web, but the method that worked for me is this.
1. Eject the tape and close the tape holder.
2. Turn the camera off and remove the battery.
3. Put the battery back in. Leave the camera off.
4. Open the tape holder.
5. Slide the tape in, but as you press the holder in to accept the tape, keep your finger pressing in on the holder, being careful not to slow the tape holder from moving downward.
6. Turn the camera on.
7. If it doesn't work the first time, press more firmly to help the tape holder accept the tape.
That's it. This method seems to work for me and lets me use the camera for a long while. If the camera is sitting unused for more than a few hours, I have to do it again. And each time I insert a tape, I make sure that I keep pressing as the tape holder lowers the tape.
Mar 27, 2008 | JVC Cybercam GR-DVL805 Mini DV Digital...
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Condensation
Here is how I fixed mine once and for all http://www.dognmonkey.com/techs/jvc-sod-condensation.html Hope this helps,Louis
Apr 20, 2006 | JVC Cybercam GR-D70 Mini DV Digital...
Panasonic NV-DS37 Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
