Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
MY Whirlpool 6ADP 5550 dishwasher does not heat the water or heat to dry the dishes. the soap dispenser does not open.
  • 1,029 Answers
The probable causes may be either the heating element is bad or its not getting the required voltage testing the heating element if you can or have the necessary tools like an ohm meter to check the heating elements for continuity and from the control board if its getting the required voltage(110/120V) .this test will confirm the problem .this can be best done by a qualified technician if you dont have the necessary tools.if confirmed then you can replace the heating element if bad. hope this helps
Posted on Jun 06, 2010
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Whirlpool dishwasher DU840SWP. soap dispenser not opening during cycle
Does the washer heat the water during the hot cycle. If it does, your soap dispenser module in the door is faulty. To install, you need to pull power plug out first,then sit on a chair in front of the door and then open the door towards yourself. Once open unscrew those screws along the perimeter of the door to enable you to remove outer panel. Once off, you can view how to remove soap dispenser. If water does not get hot, check the heater element and/or the reset (over temperature switch). Note, top rotator must move freely as well to allow hot water dispersion which on some occasions activates the soap dish. On other occasions it uses a solenoid switch.
Oct 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap left in dispenser. dried soap on dishes and siverware
After the fill cycle, check to make sure you have enough water in the dishwasher to wash effectively. You may need to have your fill valve replaced. You can test this by adding perhaps a liter of water to see if it makes a difference
Feb 25, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
394 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
