Question about Dishwashers
Where abouts is the thermistor or the heater situated in the dishwasher model DE73UK
Where is the thermistor heater fuse on a Hotpoint Aquarius FDF784
The thermistor is attached to he deposit door see that it the wires are still attached , i have seen where the wires have come off due to closing the door too hard, if they are still attached replace it , to get to it turn off power then remove all the screws on the inside of the dishwasher door , about 20 or s when you lift the door you will see wires attache dto the soap dispenser door , check all wires for conection going to the door , this is a cheep easy fix
Dec 02, 2011 | Hotpoint Dishwashers
Heater has been tested but does not heat
Hi.
Check the thermistor, it is connected in line with the heater. If thermistor reads open at the multimeter set on impedance, there will be no power to heater. Depending on model there may be more than one thermostat (thermistor and cut-off). If the problem is not a thermostat, check wiring and test the control module.
Regards.
Ginko
Aug 06, 2011 | Zanussi Dishwashers
Dishwasher has an HE error code?
"HE" is a "HEATER ERROR"
These are the possible causes for "HE" error:
1. The Circuit of Heater is troubled.
2. The Thermistor is troubled.
3. The Heater is shorted.
4. The Relay Circuit is troubled.
The Possible solutions are:
1. Repair the Circuit of Heater.
2.Replace the Thermistor.
3. Replace the Heater.
4. Repair the Relay Circuit..
Thank you !!
Aug 04, 2010 | LG Dishwashers
Our indesit dishwasher is not working and showing a A08 code on panel model DE73UK
A08 - Open/Short circuit auxiliary wash motor triac -
This is the power transistor that carries motor current. It is signaling that it is blown, but this usually happens when the circulation motor is faulty. Both need checking, and likely replacing.
You may be stuck with a bill for a new motor AND a new control board.
Jun 06, 2010 | Dishwashers
LG DWLD4080T dishwasher shows HE error message after 10 mins What is the problem?
Apr 01, 2010 | LG 24 in. LD-12BW5 Free-standing...
Delicate light flashing will not dry
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Post more information about your problem if you need more help....
Good Luck!!
Thanks
Aug 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I have LG dishwasher model LD 14AW1 I get error the message HE about 15 minutes into the wash cycle then the dishwasher turns its self off
HE refers to HEATER ERROR
The water is not heated
or the temperature in
the Tub is overheated
to over 95¡
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Feb 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
ERROR CODE : THEMISTOR PROBLEM OR WATER TEMP TOO HOT
The thermistor is located in the sump assembly next to the heater element.  The only way to get to it is to remove the dishwasher, turn it on it's side, remove the bottom panel to gain access to it.  Before you do that, remove the front door panel to gain access to the wiring harness.  About 1/3rd the way up from the bottom of the door, check to make sure that the wiring is not cut or damaged.  If you do find a broken wire, repair it and it should run fine.  Rarely does the thermistor go bad.  Good luck.
Jun 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Indesit DE43UK dishwasher. Water only gets lukewarm, intermittently gives Fault code A03 - "thermistor short circuit". Indesit says no such part as thermistor listed for this model. Indesit will...
INCREASE THE WATER TEMP AT THE HOUSE WATER HEATER SO YOU WILL HAVE 120 DEGREE WATER COMING INTO THE DISHWASHER. IF THE DISHWASHER IS NEXT TO THE SINK, PURGE THE HOT WATER LINE AT THE SINK UNTIL YOU ACTUALLY GET HOT WATER. THEN, START YOUR DISHWASHER.
Apr 03, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
