Question about Dell Dimension 2350 PC Desktop
Three lights on rear of pc are off only on mother board one green light is on what problem should be there
  • Dell Master
  • 5,660 Answers
Dell Support>Dimension 2350>Advanced Troubleshooting,
http://support.dell.com/support/edocs/systems/dim2350/advanced.htm#1118998
Diagnostic Codes>Diagnostic LED lights on motherboard.
Now where is the Green light looking at the examples given?
Posted on Jun 06, 2010
Hp m7590 fans won't start. Green light is on power supply
Try connecting the fan to another fan plug in on the mother board usually there are two or three of them . Then go into the BIOS [press delete while booting] and make sure it is turned on
Sep 06, 2011 | HP Pavilion m7590n PC Desktop
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
I have a compac presario, plugged and still no
usually ether pwr supply or mother board. i have seen older Compaq's having bad mother boards. check pwr light on front of pc case. if orange it is mother board, if off pwr suply.
Dec 13, 2009 | Computers & Internet
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
Z light with no screen
problem in mother board open the laptop and give some heat with blower
Jul 27, 2009 | Computers & Internet
MY Intel mother board D845WN can't boot
Try swapping those three connector plugs around from the front panel led lights to the other pins on the 9 pins connector, 5 in a row and 4 pins at the bottom. The bigger plug with 3 holes but only two wire will definitely go on the 5 pins row.
sirjohn
Dec 26, 2008 | Intel Desktop Board D845WN Motherboard
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Red lights on board
i never had green lights on my motherboard, they have always been red and it runs fine. the mother board was made with red led lights. if its not working right, it's probably the switches on the mother board, normally make the first switch on, and the other 3 off.
Aug 12, 2008 | DFI LanParty KT400A Motherboard
Dell Dimension 2350 PC Desktop Logo
256 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
